Results 1 to 13 of 18
    How to twin furnaces
    Sent from my HTC VLE_U using Tapatalk 2
    SE Michigan
    Scary!
    Jun 2011
    Central Indiana
    How did this hack get a hold of trane equipment
    The only true knowledge is the pursuit of knowledge
    Jan 2011
    Trane will sell to about anyone it seems. I see plenty of hacked in trane stuff.
    Tallahassee, FL
    Are those going into masonry chimney? Flues look rusted out.
    Chicagoland
    Ive only seen a few twin systems. Is it only the return that is done wrong or am I missing something?
    Apr 2012
    winnipeg
    the thing looks like a complete disaster
    Rochester NY
    160,000 btu w 3 ton of airflow? Wonder what esp was on THAT!
    Short cycling, hitting limit, and/or wet basement?
    3 furnaces run a combined horizontal flue to a chimney. 3.5 ton drives, 100K furnaces 7.5 ton Trane A/C on some ancient coil above both furnaces. Return air comes in the right furnace. 1 small filter. The Tranes are so rusty from the A/C constantly freezing up. Little damp basement room where they store pool chemicals. The techs condemned a 24 year old Ruud 60% that sits to the left of the twins. Cracked, impressive it lasted that long.
    Tallahassee, FL
    Are you guys replacing all 3 and fixing everything or just replacing what is inoperable.
    Rochester NY
    The energy bills will be your friend here if you need help. You should be able to save 50% even before looking at problems with the building enclosure.
    Jun 2011
    Central Indiana
    Quote Originally Posted by jimmyed View Post
    Around here they wont sell to you unless your a Trane authorized dealer, and they have been known to drop your dealer status if you get to many complaints. Maybe its different where you are.
    At the moment, probably just changing the split open Ruud not in the picture. The Tranes are so rusty, won't be long for them. I think a lot is from coil leaks and freezeups. Both outdoor units are on old coils. The 20 year old Bryant A/C on the single furnace has the original early 70s evap. We'll see if we have any luck getting them to change the A/C. But it never causes any trouble.
