Results 1 to 2 of 2
    Nov 2012
    Burnham Gas Heater - is it possible to light manually?
    Hi. Since Hurricane Sandy I have been without heat. I have a Burnham Gas Heater (Series 2?) and since the power went out the heater has not turned on. Is it possible to manually light the heater? Of course, I will get a licensed HVAC professional to execute the sequence if it is possible.
    Thanks in advance
    The boiler requires power to run the controls and pump so if your power is still out you won't be able to use a modern boiler.
    Sent from my HTC VLE_U using Tapatalk 2
