    Nov 2012
    Confused American Standard Freedom95 Acculink in a power outage??????
    My propane American Standard Freedom95 Acculink furnace commuicates to a separate airconditioning unit that requires a 220 power source. I'm realtively certain the furnace itself doesn't need 220 volts to operate, yet my installer doesn't have a means (or interest) to circumvent the acculink system in the event of a power outage. Our household needs are easily met with a small 110 volt generator, but it would be advantageous to operate the American Standard Freedom95 furnace with 110 voltage. How could I accopmlish an emergency 110 power source to my furnace????? Thanks fotto23
    In a machine room
    It will run your furnace just fine with the outdoor unit shut off.
    You will get an error message on the stat, but just ignore it, the furnace will run fine.
    Worry is a really gross misuse of one's imagination. -- PHM
    Mount Airy, MD
    Thread relocated to AOP
