11-05-2012, 11:14 PM #1
New Guest
- Nov 2012
- 2
Peerless Boiler Cycle time & Smart SI Thermostat help!!!
I got a new Ecobee Smart SI thermostat, which has a bunch of options on the heating section. I wanted to ask the group some question on what my optimum settings should be.
Equipment: Peerless BV-DV4 boiler, 3 zone system (2 seperate air handlers), with another pipe going to a 50gal triangle tube indirect tank. Everything is single stage, boiler LL is 125, HL is 180, Upstate NY
Questions:
1. The Tstat allows me to set a minimum heat time, which is defaulted to 5 min. Should I increase that to 10 min or a higher number to make the boiler kick on for longer?
2. It also has a heat dissipation time, which is the time the fan stays after the heat cycle. It is set to 30 seconds. Should I make this higher or does the furnance control this anyway?
Thanks in advance!
11-06-2012, 05:42 AM #2
We don't know how your air handlers are set up now. So we don't know what controls your blower.
11-06-2012, 07:06 AM #3
New Guest
- Nov 2012
- 2
11-06-2012, 05:09 PM #4
The ADPs I see have their own fan control. Depends on which model you have.
I wouldn't want less then 10 minutes.
