Results 1 to 7 of 7
Thread: fan limit control
11-05-2012, 08:44 PM #1
- Sep 2008
- rensselaer,ny
- 106
fan limit control
Just installed a thermo pride oil furnace ,what settings do you set up for the on and off on the fan control ,installed late last night ,going back to finish later in week ,heavy furnace, Thanks
11-05-2012, 09:43 PM #2
- Jun 2012
- Fayetteville, NC
- 116
The limits should already be set. What does the install manual say?
11-05-2012, 09:44 PM #3
Shouldn't have to mess with it.
11-05-2012, 10:58 PM #4
yep
11-06-2012, 03:20 PM #5
140 on, 90 off upflow
120/80 downflowLast edited by Kevin Weaver; 11-06-2012 at 03:21 PM. Reason: added more
11-06-2012, 04:28 PM #6
I would not set off any lower than 100° at the register or you most likely will get a call about it.
most likely it is already set, as has been said.
mfr should list limit, usually 200°.
on/off temps should be far enough apart to keep short cycling from occurring.If Guns Kill People, Do Pencils Misspell Words?
http://www.youtube.com/watch?feature...&v=2kX_3y3u5Uo
http://www.youtube.com/watch?v=JVAhr4hZDJE
http://www.youtube.com/watch?v=-TC2xTCb_GU
11-07-2012, 04:13 PM #7
- Jul 2003
- 24
The limit temp. varies. It's in the manual. around 190. call me at Tech support if you have any problems with start up
