    Nov 2012
    Whistling noise from ductwork
    I've been dealing with an annoying squeaking/whistling noise coming from my homes duct work. It is intermittent every 3-4 seconds and only presents itself when furnace is on or A/C. When just the fan is running, there is nothing. Any ideas? It is definitely not coming from the furnace. Any ideas?
    south louisiana
    what kind of ductwork & plenums do you have?
    flex duct is flexible.
    hard pipe is hard pipe with duct wrap over it
    plenums are either sheet metal (insulated internally
    or externally)
    or ductboard.
    usually hard pipe makes noise as the metal expands and
    contracts with temp of air moving inside vs what surrounds it.
    more info would help.
    best of luck.
    Richmond, VA
    This is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise here. Please apply to the AOPC today, thank you.
    Further infractions may result in loss of posting privileges.
    Nov 2012
    Thanks for the responses. Turns out it is coming from the gas meter outside. Something inside the meter is squeaking and the sound is carrying into the house. I must have been mistaken about hearing it when A/C is running. Anyways, I will deal w Nicor to get it addressed.
    becoming2cold16, this is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise here. Please apply to the AOPC today, thank you.
    Your post has been deleted.
