Results 1 to 13 of 13
    Feb 2012
    Nebraska
    High efficiency Lennox
    This was next door to a call I had a week ago. I would hate to work on this thing, and I have no idea how the sealtight passed inspectionName:  uploadfromtaptalk1352056710241.jpg
    Dec 2008
    Buffalo NY
    I don't see what the problem is with this from the photo.
    Join http://scopeny.org/ Shooter’s Committee on Political Education
    The world is full of sheep,try not to join the flock.
    Support the Skilled Trades, Don't DIY
    Tallahassee, FL
    Kinda close to the house there.....
    Feb 2012
    Nebraska
    I should be more clear, the side against the house is the service panel, Lennox wants something like 30 inches clearance
    Dec 2008
    Buffalo NY
    Ok. Now I get it.
    Sent from my iPhone 4s
    using Tapatalk
    In a machine room
    It's not level either.
    Rochester NY
    I thought that too, but looking again the picture isn't either. So it might not be as bad as it looks.
    In a machine room
    Quote Originally Posted by tedkidd View Post
    It looks like the Lennox logo is not parallel with the house brick lines.
    Phoenix,AZ
    I don't like those pump ups. Don't see any around here. But, i guess they are necessary in the cold climates!!!
    Athens, Ohio
    Quote Originally Posted by KB Cool View Post
    Without the pump-ups the water from the defrost cycle will freeze in the bottom of the unit. Each cycle builds it ice higher until it crushes the lowest coil and looses all the refrigerant. You don't have to like them, but you'd better use them.
    Rochester NY
    Yeah, I think it's tipping, but I don't think the dog is. Reference the unit against the dog. If the dog isn't, the units tilt isn't awful.
    Phoenix,AZ
    Quote Originally Posted by kdean1 View Post
    My heat pump may go through one or two defrost cycles a winter!!!!
    Mar 2010
    Arnold, Mo
    I guess that it doesn't get very cold in Phoenix....or doesn't stay very cold.
