Results 1 to 7 of 7
    Nov 2012
    Trane XL80, 20+years old, Inducer Fan always running
    I have a 20+ year old Trane XL80 Furnace. Within the last few days, I have detected that the inducer fan (upper fan, not the blower fan) is always running. The furnace heats and ignites fine, normal heat cycle when the thermostat calls for heat. The (past) normal behavior is for the inducer fan to come on when it the furnace calls for heat, and then shuts off after the system cools off. Looking for a pointer to what the issue might be, or things to check before I place a service call. Inducer fan runs even when thermostat is set to "off".
    Thanks.
    Bob
    Jun 2001
    Does the blower cycle off and on with the heat?
    Apr 2004
    inducer relay is stuck replace board
    Rochester NY
    Consider replacement strategy. 20 years it doesn't owe you anything, you owe it. And it's gonna start calling that debt.
    Jun 2007
    Round Rock
    Quote Originally Posted by tedkidd View Post
    He might be forced too, Trane likes to make parts obsolete after about year 15.
    I like DIY'ers. They pay better to fix.
    in a house, Appomattox, Va.
    if the inducer fan has a square housing on it, will need to call tech and spend $. the manufacturer of that inducer motor stopped making them, and the furnace will need several $ components and rewire harness.
    Col 3:23
    Nov 2012
    Quote Originally Posted by 54regcab View Post
    Blower goes on and off with the heart, normally. Thanks for all the suggestions, does sound like I need to start considering replacement at some point.
    Blower fan has a circular housing.
