Results 14 to 26 of 42
    Jul 2012
    Kansas
    Jun 2011
    Central Indiana
    Replace it. If you cant clean it with the normal methods, ie water or air, then its time for a new one.
    The only true knowledge is the pursuit of knowledge
    Salt Lake City/Tooele
    The white aldehydes that clog the orifice are water soluable. So as strange as it may seem I pop it in my mouth and use my tongue and good old saliva. What my dad did for forty years of pilot furnaces and what I found to work the best. I use a welder tip brush kit for the hood assembly.
    Jul 2012
    Atlanta ga
    wow dirt get clogged the orifice im guessing nitrogen should help this problem
    Mar 2006
    Denver/Boulder
    This what I've done since I can remember:
    After removing the orifice from the pilot assembly I get the brass brush I keep with me for cleaning all sorts of combustion components and I use a pliers to pull out a single strand of brass wire. then I run it in and out of the pilot orifice(s). works each and every time. sometimes I only need to brush the outer tip, but most of the time I pull a single strand and do it that way. Hold the pilot up to a light before and after to see the difference.
    There is no damage done to the orifice because the wire is so fine.
    What lies behind us and what lies before us are small matters compared to what lies within us.
    Two pressures, four temperatures = SUCCESS!
    Boulder Heating Contractor
    For Consumers:
    For HVACR Professionals:
    Stongsville Oh
    I have always used 1 strand of a wire brush. The steel is stiffer than copper. Learned it from an old timer in the mid 70's when everything was standing pilot. Thank You Mr Bush of Bush Furnace and Boiler!
    ckartson
    I didn't write the book I just read it!
    Oct 2012
    Corryton,TN
    the t-stat wire works great on a muzzleloader nipple,its just right!
    Quote Originally Posted by Hvac216 View Post
    Stranded #12 or smaller. Tsat wire would be too fat on most.
    Jan 2002
    tip of the mitt
    I'm a brush user too. I use a s.s. brush and pull a wire from it with pliers.
    I have my own little world. But it's OK...they know me here.
    Mar 2006
    Denver/Boulder
    Quote Originally Posted by tinman View Post
    I meant to make a note on this- I use a brass over SS for a couple of reasons. First the brass is an all purpose brush that does less damage to the surfaces worked on. Second, a SS brush has strands that are thicker, sometimes too thick for the pilot orifice. The flip side is that the brass brush strands are weaker and harder to control.
    I stick with brass and it works for me.
    For Consumers:
    May 2009
    California's Butt-hole
    Quote Originally Posted by socotech View Post
    torch tip cleaner.
    These work great and dont damage anything.....
    http://www.homedepot.com/buy/lincoln...l#.UJf3t2_A_bM
    Mar 2006
    Denver/Boulder
    Quote Originally Posted by fs1 View Post
    great Idea, except... it won't work for many pilots.
    For Consumers:
    MN
    I'm with darctangent here. I owned a few tapered broaches, but after snapping one off in the tip of my finger (trying to pick the damn thing up off the floor) I got rid of them and started using my brass brush wires. If the brass won't/can't clean it, it gets replaced.
    Jan 2002
    tip of the mitt
    I've used brass brushes too, usually there is one kicking around the truck for cleaning munchkin type heat exchangers but the brass is like trying to push a noodle through the pilot LOL. TBH in my area there are few pilots these days.
