Page 1 of 4 1234 LastLast
Results 1 to 13 of 42
    Nov 2008
    Northern California, foothills.
    Sure-fire way to clear a clogged pilot orifice?
    For clogged pilot orifices, is there some proven poker that
    will clear without making it too large? Or is this just
    really a bad idea? I was thinking maybe a toad sticker
    or dental pick. Does anybody routinely use something
    that routinely works? I've heard from senior techs
    that poking only leads to OMG pilot sizes, but those
    were only two techs and here we have many!
    Anybody?
    (I searched this forum and didn't find anything.)
    Thank you.
    Apr 2012
    Cleveland
    I usually just use some stranded wire. Works really good. It gets inside the pilot itself good too. Then I blow out the rest of the loose stuff. I had a senior tech turn me on to welding tip cleaners. Not sure who made them but they work ok on the orifices that only have one hole.
    Chicago, IL
    I also use a single stand of copper wire. the copper will not damage the stainless steel.
    Nov 2008
    So you guys have NEVER had to replace a pilot hood?
    As far as the strand of wire, are you saying one strand
    of stranded 12 gauge or whatever, or would thermostat
    wire be too fat?
    And just so we are on the same page, you are using
    this to clear the existing hole (if I could see it!), not
    to make a new one, right?
    They sell a pilot orifice cleaner at cc Dickson, my local store keeps it near the orifice drill bit kits. I don't remember what the brand name is but it works well. It's easy to break them though bc they are very small
    Calgary, Alberta
    I use a sewing needle. As long as you don't jam it in there like an idiot it won't enlarge the hole.
    Carbon/ash doesn't take much effort to dislodge.
    Oct 2012
    Corryton,TN
    fishhook
    Aug 2009
    Griffin, Georgia
    I had one Friday I just took the tube off at the gas valve and used compressed air from a can to blow it out. Worked great.
    Sent from my DROID RAZR using Tapatalk 2
    May 2012
    Upper Michigan
    I just carry a bunch of pilot orfice's in the event I can't clean one up. I should look into the kit if it makes life easier, I do have the super small drill bits for drilling orfice's (I must be spelling that wrong) but I'm sure the pilot sized are broke by now.
    Dec 2010
    Chicago, IL
    I use nitrogen and a blow gun attachment.
    It bails me out when the pilot, itself won't break loose.
    Apr 2012
    Cleveland
    Quote Originally Posted by georgelass View Post
    wire be too fat?
    Stranded #12 or smaller. Tsat wire would be too fat on most.
    Mn the state where absolutey nothing is allowed
    take it out and washed it out with hot water using a " baby booger sucker" whatever those things are called.
    works every time and you can see by the stream of water if its been damaged ( usually by the guy before you who jammed a wire in it )
    my boss thinks its possible to repeal the laws of physics
    Nov 2007
    Mississippi
    Straight pin or torch tip cleaner.
