Results 1 to 13 of 16
    Apr 2012
    Princeton NJ
    Furnace PVC exhaust leak
    Hi, now that the furnace is on, I've noticed two very small water leaks from the PVC exhaust pipe junctions. Trane direct vent xv95. Maybe 1 tablespoon of water a day. On one I noticed a blob of silicone. There was lots of extra blue sealant on the lower edge also.
    Is this anything to worry about? I do wanted the leaks stopped.
    A tech will be out at some point for fall service, but is there an easy fix? Another blob of silicone...but the joint is a bit wet. Does it need to be dismantled and revealed?
    Thanks.
    Steve
    Altmar, New York, United States
    silicone will work for a while. i would have them fix it when they service it.
    Oct 2010
    If it leaks water it could be leaking flue gases, it needs to be taken apart and completely re done with new fittings.
    Gotta have them cut out the leaking fittings and glue new ones in. Let them know before they come so they can have fitting with them.
    May 2012
    Upper Michigan
    X2 he won't be happy if he has to run for fittings. Look at it this way do you seal a leaking roof inside the house? No you have to fix leaks at the source, a new fitting and couplings and he should be able to fix it in minutes.
    Oct 2012
    Additional infractions may result in loss of posting privileges.
    Apr 2012
    Princeton NJ
    Well thanks, and I will alert the tech to save a second trip.
    I'm concerned that there could be other leaks.....the only reason I see these two is that gravity is letting water leak. Who's to say on the top side of any of the numerous couplings there isnt a small air leak? Is it standard practice to test the joints with soapy water?
    Steve
    Virginia
    it could also be condensating
    Go Trump
    Oct 2012
    Aug 2012
    North Dakota
    didnt they use purple primer durring original installation all joints should be purple
    Aug 2012
    North Dakota
    Iwould never rely on resi co detecters
    May 2012
    Upper Michigan
    They only want purple on commercial around here, it's ugly but you have no doubt it's done.
    Oct 2012
