Results 1 to 12 of 12
    Jun 2012
    Northeast
    Question Generator question related to TDH and AVR
    So I have been looking into buying a gas powered generator. It has come down to one or two things. Hoping to get some info here:
    AVR: Automatic Voltage Regulator
    TDH: Total Harmonic Distortion
    Will a generator having AVR technology give you low/low enough TDH to run sensitive electronics.
    It has come to my attention that a low TDH, 5% or lower is needed to run flat screens, laptops, etc safely. If a generator was to have a higher TDH could a quality surge protector such as Monsters filter this for electronics?
    My other concern is with my HVAC. I have a Carrier Infinity furnace w/ 2 stage coiling down stairs and a Performance series HP upstairs. I am concerned that if the power is not clean enough it will damage the circuit boards, ECM's, gas valve, etc. Or cause a problem with the ignition control. Does anyone with knowledge of this have an opinion?
    I had a guy call me the other day and said his gas furnace worked fine until he needed to use his Generac GP800E generator. I believe he said it will lite but not stay lit, could be wrong. I am guessing the generator is effecting the flame sensing.
    The only generator's I have found so far that claims it can safely run electonics are the Generac XP series which has True Power Technology and runs below 5% THD and and the Briggs & Straton Pro Series which states it's AVR can hold a 3%-6% THD.
    In my research I have found that all Generac's have an AVR. But not Briggs & Straton.
    In closing I am leaning towards the Generac XP10000E. I have left out Honda because they seem so freaking expensive for the same technology. If you can make the case for the Honda have at it and provide a M# that seems like it compares in technology.
    Thanks all
    Nov 2011
    St. Louis
    I wonder the same things even with a less sophisticated HVAC system. I've used our generator for PCs with a surge type protective strip but never an entertainment center or our new furnace using flame rectification. I was thinking, in a pinch in heating season, that I would just wire around the board and send 24 volts to the gas valve, 120 to the blower and start it manually and stop it with a separate stat. A royal pain, but it would provide some heat.
    I'm really hoping I never have to find out, but I might just do a test next time I start the generator and stabilize the gas.
    Also heard there maybe a filter of sorts to clean up the dirty juice from the generator???
    Dec 2010
    The new inverter Gensets seems to produce very clean power. Have run several pieces of very sensitive electronics with Honda's EM5000iS. Also used the EU2000 for electronics. Both produce clean sine waves.
    Iv run the EM5000 with sensitives electronics and large inductive loads starting and you dont even notice it. That think purs no matter whats connected.
    Southeastern Pa
    The bottom line for Gen power is whether or not you are producing a true sinusoidal waveform. Many modern gen sets will do this.
    Consider the load spectrum on your normal power company service. It starts as a three phase rotating sinusoidal field at the power station. For residential, one of those phase legs is fed to a transformer, where the two ends of the secondary become your two ungrounded service conductors, with a secondary center tap that is grounded at the transformer and which becomes your service neutral, tied to an earth ground of some type at your service entrance.
    Everyone on the local area fed by that phase leg from your substation has a variety of loads. Many of these loads are both inductive AND non-linear. So, the power coming into your home often has transients and harmonic distortion, and voltage is not as steady as we would like to see. This is due to the increased use of non-linear devices like compact fluorescent lighting and the many motor loads that change the power factor of the grid. As this increases, utilities will have to take more steps to improve power factor for residential grids.
    Look at the waveform of a typical CFL bulb:
    Name:  CFL Lamp waveform.jpg
    So, if you are using a modern gen set, the chances are good that the power you are producing for use in your home is more than capable of meeting the quality that you are normally receiving from your utility.
    By the way, many power utilities have quietly allowed the line frequency to vary from the sacrosanct 60 Hz that was almost a laboratory standard. Apparently, the tightly controlled frequency costs money to maintain, and allowing it to vary slightly brings a cost saving to the power industry.
    So, a true sinusoidal output from a Gen means you are likely good to go for any residential load.
    Hondas have low oil shutdown, not sure if the other engines have this.
    call your carrier dealer they have a line of standby generators that hook to the natural gas line or propane tank , carrier generators are rebadged generac
    Jun 2012
    Northeast
    Quote Originally Posted by Zoltrix View Post
    The EU series does not produce enough wattage. I am looking for at least 7-8K watts. Would prefer more. I really do not wan't to get two. Just one to power my whole panel and select loads by breakers. The EM5000s and EM5000is seem like very good generators. Nice that the is has the inverter. But they cost so much. I cant believe there technology and engines are just that much better. They are the only generator in the 5K watt range that I have seen with an inverter though. But it is not eneough wattage for me. At the cost of Hondas I would start to think about a whole house generator. But I will be moving so not a option.
    Jun 2012
    Northeast
    Thanks timebuilder. It seems that I should be safe with any of the newer higher end units. I am thinking if it has an idle control and some type of AVR I will be good. My brother inlaw has picked up a Generac XG8000E. I think I may try his out.
    Jun 2012
    Northeast
    Is there any benefit to this? I would be connecting the generator to my intire panel. The generator and panel will still have an earth ground.
    Jun 2012
    Northeast
    Quote Originally Posted by madhat View Post
    Everyone I have looked at has this safety shutdown. Pretty sure any known brand has it.
    Jul 2002
    Centerville, Iowa
    A couple thoughts, PCs aren't nearly as sensitive to bad power as many think, the first thing most non or passive power factor corrected switched mode power supplies do with the power is run it through a bridge rectifier and into a large filter capacitor, or in the case of 115/230 switchable PC power supplies, when set to 115 it is 2 capacitors in series, 1 is charged by the positive peak of the wave, the other is charged by the negative peak. Active PFC is a different animal. Some active PFC controller ICs are just picky and won't even run on a modified sine inverter.
    What is more important for SMPS is a proper wave peak voltage as that determines what the capacitors get charged up to, see what timebuilder posted. A non PFC unit only draws current when the instantaneous input voltage is higher than the DC rail voltage, hence why the current is drawn in pulses. The peak voltage of a pure sine is 1.414x the RMS so the SMPS expects the DC rail to be at 160-170 or 320-340v
    These current pulses on a cheap generator with too high of a winding resistance cause the sine wave to become flat topped, thus reducing the peak voltage.
    Also flame rectification microamp sensing furnaces require that the neutral and ground be bonded. My POS True Blue 90 runs just fine on my cheap Chinese 2 stroke ~1kw generator (the same one that is sold all over the place under various names and labeled from ~800-1200 watts).
    Nov 2011
    St. Louis
    Quote Originally Posted by danielthechskid View Post
    Good to know, Thx.
