View Poll Results: Whcih brand do you prefer to sell/service?
Voters
13. You may not vote on this poll
  • Arcoaire
    1 7.69%
  • Tempstar
    3 23.08%
  • Heil
    4 30.77%
  • Keeprite
    0 0%
  • Aire Ease
    2 15.38%
  • Ducane
    0 0%
  • Concord
    1 7.69%
  • Armstrong
    2 15.38%
Page 3 of 3 FirstFirst 123
Results 27 to 32 of 32
  1. #27
    s chester county,pa
    Quote Originally Posted by RoBoTeq View Post
    I have no clue as to what this is supposed to mean.
    ICP now has it over Allied 6 to 1 in the poll.
    I think he was hungry
  2. #28
    s chester county,pa
    Which manufacturer are you referring to? I take it you don't believe plumbers make good HVAC workers?
    Why are you not a professional member? You are missing a lot.
    ICP they used to cheap out and use smart(dumb) valves. Oh I know about plumbing, Do you need a lead pan made or roof collars?
  3. #29
    Nov 2000
    Eastern PA
    Quote Originally Posted by wogpa67 View Post
    Most of the problems with those so called Smart Valves were that the printed circuit board would separate from the contacts under it. If you tightly wrapped electrical tape around the entire valve, pressing that circuit board back down to the valve body, it usually takes care of the issue.
    Lead pan...roof collars? What are they?
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
  4. #30
    Nov 2000
    Eastern PA
    Survey says......8 to 3 in favor of ICP brands. Looks like Carrier is beating out Lennox.
  5. #31
    Nov 2000
    Eastern PA
    Anyone know if R.E. Michels dropped the Allied brands across the board, or is that only in certain areas?
  6. #32
    Still in their 2013 catalog. Lost it in our area as another distributor took on Ducane. Since said other distributor had Armstrong, Allied took Ducane from REM. However in another part of the state, REM has Air Ease and that didn't change. Michel's Airtemp (Nordyne) prices are so good, other than tie to Lennox, might be harder to sell Ducane.
