Results 1 to 12 of 12
    Feb 2007
    Fremont, Indiana
    FP SCM3 CO Detector
    Anyone else have this model?
    I am experiencing issues with very, very, very slow reaction/response time.
    I also do not see how the optional pump can be utilized with this problem.
    Co will continue to rise long after initial exposure.
    Co takes an extremely long time to come back down to neutral levels after exposure.
    This should be great trying to locate sources on a jobsite!
    Maybe I can wait 45 minutes at each test area. Customer should be very happy about that!
    Sure hope I got a defected unit!
    sent from my Samsung Galaxy Note
    Member of the "Work Exchange Program"
    "Will work for knowledge"
    "Everyone is a genius. But if you judge a fish on its ability to climb a tree, it will live its whole life believing that it is stupid"
    A Einstein
    Feb 2007
    Fremont, Indiana
    I may have posted the above while upset.
    I have many Field Piece meters, and all with the exception of the above work flawlessly.
    I'm hoping Russ can chime in here and let me know if there is indeed an issue with the unit, or if this is what I get. That will depict whether I get replacement or return!
    A Einstein
    Mar 2012
    West Chester, PA
    Well he never chimed in.. so i'll tac on my question and maybe we can get an answer, together. Related topic: SOX3 - please sell me on why I would want to purchase this unit when it doesn't even do CO. Should I have to buy a separate CO detector? That sort of defeats the cost point, doesn't it? I love fieldpiece but I was completely unimpressed with this unit. Has anyone used these who can give some feedback or maybe one of the fieldpiece guys can offer an explanation? I mean, who would buy this?
    Oct 2008
    Fullerton
    Kamer,
    Give us a call at 714 634 1844. It will be easier to diagnose the issue with a couple questions over the phone. Thanks!
    Feb 2007
    Fremont, Indiana
    Thanks Russ, will do!
    Thinking back, probably would have been wiser of me to pm you. I'm sure there is a simple solution here.
    Guess I was a little on the grumpy side at the time
    A Einstein
    Feb 2007
    Fremont, Indiana
    Quote Originally Posted by ADillon View Post
    I bought the SCM3 to compliment my SOX3. I will only be using it until I can afford the Insight Plus. I will continue to use it as a backup. But unfortunately, my plan has been deminished until a replacement SCM3 arrives from the supply house (backordered)
    A Einstein
    Mar 2012
    West Chester, PA
    Quote Originally Posted by kamersoutdoor View Post
    With the combined cost, it seems like you could just get a full combustion analyzer.
    Feb 2007
    Fremont, Indiana
    $1400 for the insight plus reporting package
    That will be my go-to guy
    The FP should be adequate enough for a backup unit should I need repairs done on the go-to.
    Crazy logic I know, but by having an excuse with the wife to have two toys is priceless
    Besides, i'll tinker with it for a bit!
    A Einstein
    Feb 2007
    Fremont, Indiana
    OK, just received my replacement SCM3 CO detector!
    Instantaneous readings, very responsive to change.
    Coffee cup test was performed, here are my results
    within 2-3 seconds I hit 850 ppm, pulled head out and ppm started dropping instantly. Within a 10 sec period unit was down to 70ish ppm, within a span of less than a minute or two it was down to 1 ppm.
    A Einstein
    Oct 2008
    Fullerton
    Here's a video on the Fieldpiece SOX3 Combustion Check
    http://youtu.be/sKMdchUPjes
    In a boiler room
    Quote Originally Posted by RussellHarju View Post
    That is one of the fastest responding o2 readings I have seen.
    Really not going to be a big seller though, IMO, until it will measure CO. Both O2 and CO must be measured simultaneously to tune a furnace, and I wouldn't drill 2 holes in everything to run 2 meters.
    Include the CO measurement and leave off all the fancy stuff like efficiency calcs and printer, keep the super fast response, and I will buy it.
    Worry is a really gross misuse of one's imagination. -- PHM
    Oct 2008
    Fullerton
    http://youtu.be/-nrB8bXpXzs
