Results 1 to 11 of 11
    Nov 2012
    Question Furnace blower will run but won't start by itself... capacitor?
    Hello all,
    I have a comfort-aire patriot 80 plus oil fired furnace. The problem I'm having is the blower fan won't start by itself, if I take the inspection cover off and start the squirrel cage myself it runs and will run fine through the cycle, until the next call for heat and the problem persists. Is there a way to tell if its the capacitor or the motor?
    We just bought the house in June and this is the first time we have needed the furnace. I think the system was sparingly used over the last few years as the previous owner burned wood also. The basement gets quite humid through the summer, when I first fired the unit and purged the air from the lines you could here a slight hum coming from the motor like it was trying to start. I shut off the power and tried spinning the squirrel cage and it wouldn't spin until I applied some force, then it broke free and spun freely. I'm hoping it isn't the motor..... any advice is appreciated.
    Jun 2001
    Could be the motor, capacitor, or even wiring. A tech can can test it and find out which it is.
    Calgary, Alberta
    Replace the motor. If it was seized and and now can't start itself, it's cooked.
    Your meter should be able to test the capacitor.
    Calgary, Alberta
    Quote Originally Posted by syndicated View Post
    Oops, you probably don't have a meter. Lol.
    Get a tech to replace the motor.
    Jun 2001
    A bad capacitor or no power to the start winding can cause the same result, may not be the motor.
    Have a tech check it out before just replacing the motor.
    Of course if the motor feels stiff and is hard to turn, time for a new motor.
    Nov 2012
    Actually the motor spins rather freely now. As far as a meter yes I have that, I worked as a contractor for years until becoming disabled, even worked as an electricians apprentice so I know my way around meters. Being on disability money is tight so I'm just looking for a little advice.
    Now if I'm going to test the capacitor what am I looking for? Voltage going to and from it? resistance?
    Dec 2008
    Buffalo NY
    Quote Originally Posted by Doug_G View Post
    Check MFDs with your meter. Caps are cheap to change.
    Sent from my iPad using Tapatalk HD
    Join http://scopeny.org/ Shooter’s Committee on Political Education
    The world is full of sheep,try not to join the flock.
    Support the Skilled Trades, Don't DIY
    Southeastern Pa
    I think the bottom line is that if the value on your meter agrees with the cap label value within 10%, then you should replace the motor. It IS possible that you have an open aux winding.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Jun 2001
    I'd replace the cap first, if it ends up being a motor you will want to replace the cap anyways. Caps are cheaper than motors.
    Feb 2012
    Toronto Canada
    X2 I lost count on how many times I have made a new customer cause the Tech before me tells them crazy amount for motor cap etc and i come along and replace cap and it works fine. Test cap first.
    Seems like a lot of DIY info.
Tags for this Thread
