Results 1 to 7 of 7
    Oct 2006
    Are the fan switches on a coleman furnace adjustable. This furnace sits in a trailer. The blower motor runs for about 3mins after thermostat is satisfied. Is this the correct amount of time or is it too long?
    Jan 2006
    Your fan will run until your heat exchanger has cooled down enough to "break" fan switch. Is your thermostat overshooting its set point because of this?
    Nov 2001
    east kansas
    Is your filter clean. What about your A-Coil?
    When was your last tune-up?
    Nov 2000
    Eastern PA
    Sounds a little long. Are you certain it is 3 minutes, or might it just seem that long
    Are the homeowner of this unit or a tech working on it?
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    Oct 2006
    I am a service tech. Adjusted anticipator on thermostat and watched cycle off. It is a 7600 series coleman furnace and the fan shuts off at 2min 30 seconds. Is there some sort of timer on this furnace that breaks contact after so long.
    May 2003
    Dixie
    look at the unit...a tech should be able to tell what cycles the blower off.....
    It could have a fan limit switch with the fan switch fixed at 105-20, or a fan switch at 110-20, or 130-35.
    You'll have to look for yourself which one is controling the fan.
