Page 22 of 22 FirstFirst ... 121516171819202122
Results 274 to 284 of 284
  1. #274
    Oct 2011
    Chicagoland Area
    Quote Originally Posted by Joseph'bidness View Post
    Timing is everything, really.
    Seeing as this thread is almost 4 months old, you are absolutely correct...
  2. #275
    May 2012
    Upper Michigan
    Quote Originally Posted by 2sac View Post
    Boy your a real smart Alec!
  3. #276
    Jan 2013
    Ringgold, Ga.
    WOW!!
    I thought I was gonna learn something here.
    30 minutes of my life, I'm nor getting back.
    note to self. get plenty of wire nuts for them ground thingys.
  4. #277
    Oct 2011
    Chicagoland Area
    Quote Originally Posted by Joehvac25 View Post
    I deserve props! That was DAMN funny if I do say so myself.
  5. #278
    May 2012
    Upper Michigan
    It was pretty good I must say lol
  6. #279
    Southeastern Pa
    That makes me wonder if it was ever fixed at all...
  7. #280
    NC
    PACNW. Great sig line.
  8. #281
    Sep 2013
    whoa,whoa, whoa, young fella.first of all the burner isn't going to light twice on "OLD GAS".first make sure your flame rod is clean,the porcelain is not cracked and the wire and connections are clean and tight all the way back to your ignition control.also make sure your burner ground is clean and tight.next"GET A MAGNEHLIC OR WATER MANOMETER" and get it hooked up.you claim to have 4 years exp.but you don't have even the basic tools to do the job right.next the flame signal does vary from control to control so try and find out your controls microamp range.next fire the unit and watch your gas pressure gauge.if you have your pressure and an actual flame you'll be able to read your flame signal.if your flame signal is in fact low and your sensor is clean tight and not broken,then you have a bad ignition control.remember the rectification thru the flame rod does not generate the signal,but only completes the path.the ignition control generates the signal.good luck and get your tools a little a time if necessary.i remember when i first started.drop just one 6 pack a week and you'll be surprised how the tools will add up!!!
  9. #282
    Oct 2011
    Chicagoland Area
    Quote Originally Posted by big papa paul View Post
    Dropping a 6 pack is NEVER a good idea. If you want to save money, water down the baby's formula or leave the diaper on an extra day. A little Febreeze will take care of the smell and if the kid doesn't venture outside, you don't need to worry about flies.
  10. #283
    Aug 2010
    Quote Originally Posted by Youngwiseman View Post
    I dont have a water manometer to check the gas pressure in and out the valve, any suggestions
    GET ONE!!!
    I haven't assembled it yet though.
  11. #284
    Sep 2013
    Hey guys. Not sure if you fixed this issue.
    The coils on the gas valves should read infinity to 1300ohms. -+150ohms.
    It sounds like the coils don't have the strength to keep the valve open. Lg dryers have this issue
