Page 21 of 22 FirstFirst ... 11141516171819202122 LastLast
Results 261 to 273 of 284
  1. #261
    Southeastern Pa
    Quote Originally Posted by welling service View Post
    I can't believe this thread went on for this long but I did get a lot of laughs from it. In reality it should have stopped after his first few post.
    Using 20/20 hindsight, that's right.
    However, we are a VERY forgiving bunch, and we also extend Pro status to some students, a few of whom are just as inexperienced as the OP, so it was a calculated risk that this guy might have been thrown to the wolves by a boss who put him in a truck, and said "go fix stuff." That dynamic is not unknown in the business.
    Once it was clear what was really going on, several of us wanted to see if this guy could take the clues and put them together, and then post his solution, perhaps finally answering the many questions that we asked.
    In this case, the calculated risk fell flat on its face. Even so, it was instructive in ways the OP never intended.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  2. #262
    Nov 2012
    Barrie, ON
    I had a no heat service call this Friday evening after a new customer of mine had described the same problem as what was discussed in this topic. Upon arrival, I said my hello's and took a look at a 14 year old York mid. The customer was confounded as to what the problem was with his furnace - he spent considerable time trying to figure it out. The burner would light up and go on for about 7s and shut down. It would repeat this action until the furnace locked out. Of course, I had the problem licked in under 5 minutes - the customer nearly dropped a load in his pants when he saw how easy I had fixed the problem. As it turned out, the customer is an electrician.
  3. #263
    Sep 2011
    It was a fun read up to page nine and although I am very sure it gets better... There are better threads for me to actually learn something from or help someone with, perhaps. IMO this was a gag thread
  4. #264
    Southeastern Pa
    Quote Originally Posted by butternut View Post
    Maybe.
    I'm thinking it was just a guy who THINKS he knows enough to BE a tech, but does not.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  5. #265
    Feb 2013
    when heated sand turns 2 glass. glass is an excellant insulator. u dnt want ur FS to b insulated. I use an emery cloth
  6. #266
    NE wisconsin
    You picked a great thread to introduce yourself on njhove, do you work with youngwiseman? We've missed him around here, he hasn't been around much since this thead. Welcome aboard, looking forward to more furnace repair wisdom from you.
  7. #267
    Southeastern Pa
    No need to make additional posts to this unfortunate thread.
    I just hope the OP is not out there subjecting the public to his style of repair...
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  8. #268
    Feb 2012
    Durham, NC
    Damn ya'll. Give him a break, he knows the sequence of operations and EVERYTHING!
  9. #269
    Feb 2013
    New Jersey before and after Texas
    Your gas valve should have voltage for about four seconds after the igniter has glowed which is about seventeen to roughly twenty five seconds. Measure the voltage at the valve and see if it is dropping out from a failed relay. Check the limit switch inside the cabinet some smart Alec could of put it in backwards in the summer to get an easy call for winter.
  10. #270
    Feb 2013
    Timing is everything, really.
  11. #271
    Feb 2013
    north georiga
    is that cat chewing on heat strips?
  12. #272
    Southeastern Pa
    Quote Originally Posted by njhove View Post
    I m sur u don wnt 2 use tx style at ths 4um.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  13. #273
    Feb 2013
    north georiga
    it should empty the tube
