Page 18 of 22 FirstFirst ... 8111213141516171819202122 LastLast
Results 222 to 234 of 284
  1. #222
    May 2011
    Western, KY
    Quote Originally Posted by hkempf View Post
    Pull the connector off the flame sensor hook one jumper from your meter to the flame sensor and the other to the wire you pulled off of it, fire the system, you should get 0.5 microampers
    Do you mean more than 0.5?
    Different manufacturers have different minimum microamp requirements. Many units that have clean, undamaged flame sensors will get over 2.0 microamps during operation.
  2. #223
    Nov 2001
    east kansas
    This unit still broken? Anyone know which furnace he is working on? Has the OP checked in lately?
    Beware of advice given by some guy on the Internet.
  3. #224
    Southeastern Pa
    Guys, pay attention. This guy is not a tech. Let's not post info for DIY use when search engines index this forum
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  4. #225
    Southeastern Pa
    Quote Originally Posted by Milk man View Post
    1) Unknown
    2) No
    3) No
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  5. #226
  6. #227
    Rochester, NY, USA
    ok pal if you can't get this thing going, here is what you need to do (although this is against forum rules, Im going to fix this for you)
    1) Make sure the fuel line is plugged in and locked into the receiver
    2) squeeze the primer bulb several time til it feels "hard"
    3) Pull the choke all the way out
    4) grasp the "T" handle on the pull rope and pull with some authority. (you may have to do this several times)
    5) this should start it up. If it starts, wait a few seconds and then push the choke all the way in
    If it doesn't start, step back three to four feet and kick it as hard as you can, then repeat the process
    Lets me know if this helped???
    Ok, Im just bust'n your balls, if it didn't start it's probably because of that damn ethanol.....Good luck, have fun
    Measure Twice
    CUT ONCE
    Crap, throw that away and get a beer
  7. #228
    May 2012
    Upper Michigan
    Quote Originally Posted by jmac00 View Post
    I have seen the primer balls go bad, if it won't fire replace the primer ball and try it then, hope I don't get banned.
  8. #229
    Rochester, NY, USA
    good call, I forgot about that, gezzz I think we are borderline with this DIY stuff
    Measure Twice
    CUT ONCE
  9. #230
    Southeastern Pa
    Holy cow. I was a go-kart kid when I was 11, and that sure brought back some memories!!
    BTW, Sta-Bil makes a fuel treatment to mitigate the effects of methanol in gasoline powered equipment.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  10. #231
    British Columbia, Canada
    I see where I've been going wrong. I always start with a Happy Gilmour style kick!
  11. #232
    Mar 2009
    Mid-Mo
    Quote Originally Posted by koolkahuna View Post
    This is only appropriate if you use the "HIIII-YAAAA" method.
  12. #233
    Rochester, NY, USA
    that only works if your using Hy-Karate deodorant
    Measure Twice
    CUT ONCE
  13. #234
    Got it.
    Now I'm working' on the battle cry. Heehaw.. Hihowareya...Hallelujah...HiuuYaaa!
