Results 14 to 26 of 26
    Apr 2010
    Ontario
    Centrifugal switch at the end of the motor proves the motor shaft is turning. Of course it doesn't help if the blower wheel has rusted off. Then your using the other safety device. Flames from delayed ignition melting wires.
    ENJOY THE RIDE
    May 2012
    Upper Michigan
    Quote Originally Posted by Peztoy View Post
    Saw that first hand too? Lol
    when i first read the thread, my original answer was
    INDUCER MOTOR WHISPERER!
    May 2012
    Upper Michigan
    Quote Originally Posted by supertek65 View Post
    Hey know I thought of that to but wasn't sure what kind of crowd I was dealing with lol
    LIAR!!!!!!!!!!!!!!!!!!!!!!!!!!!
    May 2012
    Upper Michigan
    C'mon your not the only intellectual on here lol. Il back off you can have the credit!
    thank you! thank you very much!
    okay you can have that one and i will take
    DR.INDUCERLITTLE!
    Southeastern Pa
    I talk to myself while I check inducer motors. Does that count?
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    you dont need dr inducerlittle
    you need dr phil!
    who is from kansas city by the way!!
    Oct 2011
    Chicagoland Area
    Do you say nasty things?
    S.W. Ontario,Canada
    Years ago I worked on a Trane rooftop that used a sail switch that the inducer closed on inducer startup, then fired the burners.
    If every a...... could do this,I wouldn't have a job...
    Oct 2012
    Where we mow our own grass
    Melting wires is also the redundant safety device for york sunlines and old aaons too. Not only protects you from the blower wheel falling off the inducer, but also protects you from a heat exchanger with big holes in it.
