Results 1 to 13 of 26
    What talks to the inducer motor ?
    old rooftop package carrier weathermaker
    Im replacing the belt on blower , get that done , fired it up to check flames , and im hearing the inducer kick on , then flames come on , and im like ..... how in the world does the board know the inducer is going ok ?? Theres no vacuum pot.
    Does the motor have a sensor that knows if the armature is spinning a certain Rpm ?
    yes it has a little sensor.
    i forget what they are called?
    they do fail frequently, i have changed a few.
    Calgary, Alberta
    It would be a centrifugal end switch that makes at a certain rpm.
    Not the best way to check draft
    NW AR
    centrifugal switch
    Oct 2011
    Chicagoland Area
    4 wires on the motor. 2 are line voltage and 2 are low voltage
    May 2012
    Upper Michigan
    Yep centrifugal, if motor spins it closes.
    Apr 2011
    West of DFW
    Please inspect that heat exchanger!
    May 2012
    Upper Michigan
    We have that exact pos on Hardee's here, Check the HX, had to replace the one we service last year and many other parts.
    May 2012
    Upper Michigan
    Quote Originally Posted by blazey10 View Post
    Wow both a 6:55 but you were seconds ahead lol
    it's a Hall Effects Switch
    Sun was going down when i finished , ran out of time to check it over more.
    I will advise them its old as dirt and needs additional looking over of the HX tomorrow.
    May 2002
    Its either a centrifugal switch or a "hall effect" sensor depending on age of the unit ...
    http://sensors-actuators-info.blogsp...ct-sensor.html
    mikeacman
    yes
    hall effect!
    that is what i was thinking of!
