Results 1 to 8 of 8
Thread: Trane Reliatel
    Jun 2011
    New Mexico
    Trane Reliatel
    I am looking for a brief explanation of Reliatel. Is it part of an overall building management system? Or is it simply an upgraded controls packaged on a rooftop unit?
    Jun 2009
    StL, MO
    The latter.
    UA LU 562
    Jun 2011
    New Mexico
    Thanks Dave
    Mar 2011
    Long Beach, CA
    Are you looking for specific information on the Reliatel. You know that it is only available on Trane OEM equipment and is an upgraded version of the Microtel.
    Jun 2011
    New Mexico
    alcomech,
    I don't need anymore than that. I saw it on a plan and was curious. Thanks
    Mar 2015
    Straughn, IN
    Hello everyone, hope this is the proper place to post this question.
    Was wanting some thoughts on an issue i'm having with a trane RTU with reliatel.
    It is setup with KMC Building management system which initiates the call for heat and cool.
    kmc triggers an ice cube relay that calls.
    The relay calls for cooling, the compressor starts, runs for a bit then shuts down without ever loosing the call from the relay.
    Its not the low press switch, or the high temp switch.
    Is it possible for the reliatel to be over riding the call in some way?
    The unit is only a year old. and very possibly has a configuration or wiring issue. previous techs had no clue how kmc controller was supposed to work with unit.
    Any ideas?
    Thanks Ed...
    Feb 2011
    Chesterfield, Virginia, USA
    Does it have a "Froststat" (freezestat)? Does it run three minutes and then off for about seven?
    Mar 2015
    Straughn, IN
    I did get back to the unit today. It doesn't have the freezestat option. It would run for arbitrary times such as 5 minutes one time then 10 minutes next time. Pretty sure I found the issue. It had a poor connection on one of the wires.
