Results 14 to 21 of 21
11-01-2012, 09:20 PM #14
- Jul 2012
- 18
There many ways to write this.
If sch1 = On Then
If OAT Between 'OAT_Setpoint' - 1 'OAT_Setpoint' +1 Then
'Fan_Start/Stop' = Off
Else
'Fan Start/Stop' = On
End If
Else
End If
You could also use a switch with a CO like bdivell said.
switch (FAN, CO1, 60, 50)
11-02-2012, 05:12 AM #15
I think this fella should probably call his normal control tech in. That is probably the most basic SOO I have ever seen.
I mean come on. Turn on Output when Temp < SP -1 then turn it off when Temp > SP +1? If you are a control tech then you, or someone you work with, has done this 1 million timesFollow me @blankscole
11-02-2012, 07:50 PM #16
- Oct 2012
- 8
I'm a stationary engineer attempting to learn something new and exciting, pardon me for bruising anyones egos in the process. Perhaps my judgement was a bit cloudy as to joining a forum for help as a 2nd day novice... regardless I appreciate the help that has been given. Jmelvin I'll give that snippet a try on Monday, thank you.
11-02-2012, 09:59 PM #17
- Mar 2008
- Kitchener, Ontario
- 491
Hi Cujo67,
A little bit of advice, buy a DSC or DAC and work on it at home, If you want to learn controls for the most part it isn't done from 7 - 4:30.... I am not being negative just saying if you are unable to read code don't expect to be able to write it.
11-02-2012, 10:37 PM #18
- Jul 2012
- 18
If you can get a GCL+ programming book. (Search Google) And if you have the ability to get into George U. Those are good starting places. I can send you some links.
Sent from my SAMSUNG-SGH-T989 using Tapatalk 2
11-03-2012, 06:40 AM #19
I appologize Cujo. Just seems like a DIY-er type of question. Some of those make their way into the forums.
Try this. Unless I misunderstand what you want
If Schedule on then
Switch(Fan Start/Stop, Room Temp, SP-1,Sp+1)
Else
Stop Fan Start/Stop
Endif
11-03-2012, 10:24 AM #20
Contact Trinity, they are your local SF Delta partner.
kontrol out"Can't we all just get a Lon?" - Garry Jack
"BACnet: integration or interrogation?" - The Janitor
"Open protocols? You can't handle open protocols!" - Nathan R. Jessup
“What’s that? Aaa… open protocols? Don’t talk about…. open protocols? Are you kidding me? Open protocols? I just hope we can hardwire an interface!” - Jim Mora http://www.youtube.com/watch?v=U7fjDS0jKiE
11-03-2012, 11:01 AM #21
Cujo67,
There has been numerous suggestions and assistance given from the Members here in the "Open" section if this forum, However this thread has gone over the amount of help we are able to provide in this "Open" section of this site and the Thread is now closed.
Cujo67, try getting your post count up and then apply for pro membership where these sort of questions may be discussed in greater detail behind closed doors and out of the eyes of Goggle in our "Pro" sections.
