Results 1 to 13 of 20
    Oct 2012
    No flame signal? Replaced flame sensor but no joy
    Hi, I have a Goodman Furnance #GDS80703ANA, and the led flashes 7 times, saying that there is no flame signal. When I turn it on, the blower starts, the ignitor glows, but it doesn't start burning, there is no flame at all. I've replace the flame sensor, but still nothing. Please let me know what you think! Thank you!
    Jun 2006
    Richmond, VA
    Can't sense what isn't there
    I wish I had a $1.00 for every response I deleted.....
    "Decidedly Superior in a twisted pathetic way".....
    Northeast Ohio
    What he's saying is since there is no flame, there is nothing for the flame sensor to do, albeit you wasted your money on a part that you did not need. We can't get into DIY as it is against the rules. You will need to call an HVAC service company to properly evaluate your furnace.
    DEM
    Fort Worth, TX
    Did you pay your gas bill?
    Building Physics Rule #2:
    Building Physics Rule #3:
    Oct 2012
    Quote Originally Posted by Shophound View Post
    Yep, gas is on, my water heater is gas and it works. I'm thinking that its the gas pressure switch. Am I supposed to smell any gas when it tries to start?
    Time to call a service tech. Sorry, this is not a DIY site.
    Dec 2008
    Buffalo NY
    You need to call a tech.
    Sent from my iPad using Tapatalk HD
    Join http://scopeny.org/ Shooter’s Committee on Political Education
    The world is full of sheep,try not to join the flock.
    Support the Skilled Trades, Don't DIY
    Apr 2012
    winnipeg
    yep...save the other flame rod... it will be good for a spare in the future.....
    keep throwing parts at it; even a blind squirrel gets a nut once in awhile.
    Fort Worth, TX
    Quote Originally Posted by ShibaSig View Post
    If the pressure switch is bad, you may have issues beyond just the bad switch. Hire a technician who performs combustion analysis. He can not only get your furnace running again, he may be able to find out why it failed in the first place. Don't screw around with DIY when it comes to furnaces.
    Oct 2010
    I doubt it's the pressure switch, call a pro to fix it. If you keep throwing parts at it you'll probably spend more than it would cost for a tech to diagnose and solve the problem before you finally fix it or end up calling a pro bc you can't fix it.
    Jun 2001
    no gas is getting to burners. call a tech to find out why. could be just about anything. boards and gas valves are expensive parts to guess with.
    Sep 2012
    Ottawa, Canada
    This is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise here. Please apply to the AOPC today, thank you.
    Further infractions may result in loss of posting privileges.
