Results 1 to 2 of 2
    Oct 2012
    Warren, Michigan, United States
    Hmm Help with Lennox RTU Mod GCS24
    Hello! I am performing maintenance, and for the life of me I cannot find a terminal strip on this unit so I can jumper it out. It is hooked up to the Novar Control System. Does anyone know where the terminlal strip is located or if there is another way of jumpering it out at the unit itself? All is see above the Compressors are two Contactors for comp 1&2, Blower Contactor a control board, and a couple of relays. (This is about the 1,000th unit ive worked on with the Novar system and they all have had the terminal strip in the control box, but not this particular model and I have about 13 of them on the Roof!!! Help!!! It is a Lennox 'Epic" with a Mod# of GCS24-953-200-1G Serial# 5696C 04451. Voltage 460-60-3. Note:Need to jumper heat only W1 to the R24V to verify heating operation....Any help would be Greatly appreciated!!! Have a great day and dress warm my fellow tradesman!!
    Oct 2012
    Nevermind I found it in the blower compartment under the blower in a little box.
Plumbing Talks | Contractor Magazine
Forums | Electrical Construction & Maintenance (EC&M) Magazine
Comfortech365 Virtual Event
