Results 1 to 9 of 9
    Sep 2011
    difference between return and supply air
    What shuld be a diffrence between return and supply inheat mode on a heat pump
    Outside temp45
    inide t set to 72
    temp inide 70 aux heat is off
    heat pump is trane 12 year old 10seer 2t size of a home 1200sq
    thx what temp i shuld get on closest registr to furnnenc after 15min of working ????
    Oct 2010
    With no aux on it should be ~95-105F.
    Oct 2010
    If its lower than ~90F you probably have a problem with the unit or leaky ductwork
    Sep 2011
    its around 82-85 ,, diffrent between in and out its 12 duc is ok ?
    Oct 2010
    Sounds like its either low on refrigerant and/or leaky ductwork. Could be other things as well, have a pro come give it a check up.
    Sep 2011
    a duch is shor 3 ft at closest registry where checkedtemp what about inide txv pro just replaced txv on outside unit and checked freon?
    Oct 2010
    The txv on outside is the only one used for heat mode, txv on inside is for ac mode. He may have left a freon leak when the valve was changed. If its not able to keep up at 45F outside it won't have a chance at all of keeping it comfortable when the temp gets lower
    Oct 2010
    It 46F at my house and my hp is putting out 101F heat with no aux at a register ~35' from unit.
    SW FL
    Quote Originally Posted by hochla01 View Post
    What was the temperature in the same location under similar conditions a year or two ago?
    What's the temperature with the Aux Heat ON?
    Like jtrammel stated in #3, < ~90'F ( 95'F for me) is definitely an issue.
    Designer Dan
