Page 4 of 4 FirstFirst 1234
Results 40 to 48 of 48
  1. #40
    Southeastern Pa
    The JCI replacement is the black UEI box.
    Here is the replacement style module.Click image for larger version.
Name:	UT Module.JPG
  2. #41
    Oct 2011
    Chicagoland Area
    I've seen one before, just didn't remember it.
    Local 597 Service Fitter
    Metal Trade Journeyman
    PAY ME NOW OR PAY ME LATER
    It was working when I left...
    WWFD
  3. #42
    Dec 2008
    Buffalo NY
    Here is the one that York is supplying here. Click image for larger version.
ID:	323881Click image for larger version.
    Sent from my iPhone 4s
    using Tapatalk
    To the man who always did it right. I love you dad and I will miss you to much for words.
    Stay Thirsty My Friends
    Support the Skilled Trades Don't DIY
  4. #43
    Mar 2011
    North Carolina Piedmont Area
    So whats it not doing now.
  5. #44
    Dec 2008
    Buffalo NY
    Quote Originally Posted by alcomech View Post
    I have not heard from him so it must be working ok.
  6. #45
    Jun 2011
    Detroit vicinity, Michigan
    Replace the roll-out switch. This is a common problem with these units. You will read continuity, and 24V through the switch to the R.O. terminal, but it will not pass the proper current to operate the board.
    I was that kid once. Now I replace it with every failed module.
  7. #46
    Southeastern Pa
    Quote Originally Posted by Workin4TheMan View Post
    When the switch has limited current capability, you can read a voltage drop across the rollout switch when the circuit is energized.
    Replacement of the rollout with the module IS a good idea.
  8. #47
    Oct 2011
    Chicagoland Area
    I've always used the Honeywell with the continuous retry to prevent nuisance lockouts. Just needs a little rewiring.
    WWFD
  9. #48
    Sep 2012
    Ottawa, Canada
    I had a similar call with no ignition, and was told it was running motor due to venting failure. I am still waiting for final answer from my boss this week as they replaced venting on friday.
