Results 1 to 13 of 70
Thread: Natural Gas Pressure
10-30-2012, 06:38 PM #1
- Feb 2010
- 17
ok, I have a furnace that wouldn't come on for a customer. Its a Carrier natural gas hot surface ignition system. I came up to it and It went thru the initial cycle for heat, until the gas valve was energized. No gas outta valve. I got 24v to it, I checked the wiring, ground to furnace. everything looked fine. I had a universal valve on my truck and put it in. Same problem. Tomorrow im going back with my gas pressure test kit. I doubt its the new valve, but not impossible. What should my pressure in and out of the gas valve be? The furnace tag says min. 4.5" max 13.5" out...The pressure coming in should be what? I opened the shut off valve with the flex off and it seemed alittle week and was whistling as it was comng out. My guess is either the gas valve factory settings too low or the incoming pressure is weak...any suggestions...thanks
10-30-2012, 06:54 PM #2
- Nov 2004
- Western NY
- 943
10-30-2012, 07:03 PM #3
- Feb 2010
- 17
10-30-2012, 07:10 PM #4
Really your going to hurt someone, all the info you seek is on the cabinet. If you didn't have a manometer how did you determine you had no gas? Is the ignitor glowing and in the path of gas. How do you change a gas valve without confirming pressure?
10-30-2012, 07:11 PM #5
We use manometers to measure the gas pressures. Guessing gets expensive. If you do not know how to check pressures I would ask your service manager to give a class on gas pressure testing. good luck.
Living the dream !!
10-30-2012, 07:20 PM #6
Most people on here know already but Monday I watched a guy get hauled out of a house in a body bag from CO poisoning from a boiler, do you want that on your conscious?
10-30-2012, 07:31 PM #7
10-30-2012, 07:33 PM #8
- Feb 2010
- 17
ok...gonna check my pressures tomorrow...I made sure gas valve was off until the correct diagnosis was made and fixed. I didnt want to jeopordize anyones life. Im here looking for help from experience techs and thankful for any positive help.
10-30-2012, 07:36 PM #9
Good at least your not cocky about it maybe there's hope after all lol. It will say on the valve also, 13 is the maximum input natural would be 3.5 out, but don't take my word, find out yourself so you are aware of how to find information.
10-30-2012, 07:54 PM #10
Are you working for a company ? if so maybe ask that a senior tech assists you on this one. Your messing with s**t that can and most likely will shorten your career. 13.5 out ?? I hope that is a typo. This has to be a joke.
There is no bad beer, some just taste better than others.
10-30-2012, 07:56 PM #11
10-30-2012, 07:58 PM #12
No DIY, if you are a pro then apply for pro membership.
"If anybody can draw on the power, where do we put the meter?" - JP Morgan before pulling Tesla funding
10-30-2012, 08:05 PM #13
Can you post tech to tech without pro status?
