    Oct 2012
    Beckett 2 pipe question
    Hi, can you tell me approximately how much fuel oil gets
    returned to the tank via the return line on a two pipe system setup when
    the burner is running? It's a Beckett with type "A" pump. Thanks. Jim
    Virginia
    as a guess probably 10 gallons a hour. i am not a fan of 2 pipe systems because the filter does not last as long. i would convert it to a single pipe with a tiger loop
    Stuff happens
    Quote Originally Posted by catmanacman View Post
    A lot more then 10 gallons.
