Results 1 to 13 of 30
Thread: Appion G5 twin
    Appion G5 twin
    Hi there gents , I just purchased one and must say , instantly impressed! liquid recovery ratings are exactly as advertised.
    I`m just wondering if anyone can share any experience pros&cons and obvious do`s & dont`s , as to get best performance and extended life from machine, thank you in advance stan
    Keep it simple to keep it cool!
    Jan 2011
    Is this thread in the right forum? The Appion G5 twin may be a good machine, but I don't think I'd be proud of the fact it took 18 hours to recover 4000 lbs. of R-134a like they state in their brochure. Almost two and a half work days, are you kidding me?
    Chicago,IL
    Keep an eye on the recovery tank pressure on warm days.. Other than that, its a nice little machine..
    Home of the newly wed and the nearly dead
    Quote Originally Posted by KnewYork View Post
    You can pump out 4000# of liquid in 1/3 that time. Getting the vapor is what takes all the time. I wouldn't try it with an Appion machine, though. IMO, if you're dealing with something that has 4000# of charge, that's like bringing a squirt gun to a nuclear war.
    Truth is still truth, even if no one believes it. A lie is still a lie, even if everyone believes it.
    "It's called the american dream because you have to be asleep to believe it" -George Carlin
    "A nation of sheep begets a government of wolves" -Edward R. Murrow
    "I have problems just like you. One time, my dancing horse almost fell into my car elevator" -Mitt Romney
    Buy american made goods & support locally owned businesses!
    Mar 2009
    Mid-Mo
    Quote Originally Posted by Tech Rob View Post
    Haha. I've pumped 75 lbs in one hour using a subcooler.
    On the bigger chillers we pack the 125 pound cylinders in ice and have pretty good success with it.
    Last one I did ended up pulling out 185 pounds in 5 hours and pumped it back in in less than an hour. vapor.
    Oct 2006
    Central Texas
    The the little g twins are good for about 150#'s and down. I've adapted 1/2 " hoses to it, and it'll move some refrigerant. We pulled a Carrier pump-out compressor of an old 19EB, we use that for recovering large amounts of medium/high pressure refrigerants.
    Sic Semper Tyrannis.
    Dallas ,Texas
    They have a diagram in their book for helping keep the tanks cool.
    Quote Originally Posted by y7turbo View Post
    Chicago,IL
    Quote Originally Posted by Dallas Duster View Post
    I've read the manual.
    I have my own ways to keep the tanks cool and the machine recovering without the use of ice, water, or the ways they tell you in the book.
    8th grade
    i met a guy in garland texas did a lot of 19xr work.
    he made a manifold out of 2" CU and hooked up 3 g5 twins to the manifold.
    he showed me pics and said basic pump laws applied so he could pull 18lbs/min
    I think 1,080 lbs/hr is pretty good?
    just sayin?
    i have used two g5's at a time push pull or pull pull and have no problem getting 3-400lbs/hr liquid!
    vapor is vapor!
    whatever you use you gotta heat it up and let er run all night if it is a big machine!
    either way!
    g5 is good!
    we have the HUGE trane high speed recovery machine at work!
    it is heavy and bulky!
    still use it on 1,000 tr or more!
    I WILL SELL WORK,GENERATE BUSINESS, GO GET NEW CUSTOMERS!
    YOU SHUT THE HELL UP AND QUIT RUNNING YOUR MOUTH!
    8th grade
    ryan
    that is a long time!
    are you push pull or just liquid?
    8th grade
    g5 push pull is 16 gpm!
    obviously 2 of em is 32 if you have a place to hook it up?
    you should be able to push pull 185lbs
    150 of it in 20 minutes and then suck on that vapor the last 35lbs or so for an hour!
    of course this would be hard on a HOT day on a HOT roof!!!!!!!!!!
    thanks guys , luckily I dont work on many systems w 4000lbs in them, I use a water hose trickling on cylinders to keep pressures down , Ive always played with the idea of getting a 1/2-3/4 hp condensing unit and building my own high capacity unit, think this little bad boy is gonna be great for my commercial chillers.
    Dallas ,Texas
    Hey me too but I have to use 2 water hoses most of the time.
