Page 1 of 6 123456 LastLast
Results 1 to 13 of 72
    Home of the newly wed and the nearly dead
    Another Chiller Teardown & Rebuild
    770 ton Trane CVHF, bearing failure and a worn oil seal
    Click image for larger version.
    Removing the economizer
    Economizer sealed up for storage to prevent rust
    Rigging of suction elbow
    Removing suction elbow
    Suction elbow covered to prevent rust
    Compressor and evaporator flanges covered to prevent rust and prevent debris from falling in
    Preparing to remove suction cover
    Removing suction cover
    Rigging the suction cover down and a shot of one of the work-tables where all of the tools return when we are done with something
    Checking the run-out of the 1st stage impeller
    Truth is still truth, even if no one believes it. A lie is still a lie, even if everyone believes it.
    "It's called the american dream because you have to be asleep to believe it" -George Carlin
    "A nation of sheep begets a government of wolves" -Edward R. Murrow
    "I have problems just like you. One time, my dancing horse almost fell into my car elevator" -Mitt Romney
    Buy american made goods & support locally owned businesses!
    This is where the inter-stage shaft seal mounts on the 1st stage diffuser
    Looking at the motor journal bearing support with the oil seal, mounting plate, and internal oil line removed
    Setting up the dial indicator to make sure we do not move the shaft too much when we remove the bearing and bearing support
    Another shot of the dial indicator setup
    The failed journal bearing
    Dowel pins installed to make sure the bearing support goes back exactly where it was before
    Removal of bearing support - we monitored the shaft at all times with the dial indicator as it could move no more than .003" in any direction
    Another shot of the removed journal bearing support and the bad back oil seal
    Inside the motor
    Chicago,IL
    Something wrong with the second post, I cant see the pictures, first post is ok.
    Quote Originally Posted by y7turbo View Post
    Fixed. This new site format is glitchy.
    Chicago,IL
    Quote Originally Posted by Tech Rob View Post
    Works now, Thanks for sharing.
    Thanks for checking it out and commenting!
    Chicago,IL
    Any idea on what the weights were on the parts you removed?
    Economizer 840#
    Suction elbow 700#
    1st vane assy. 400#
    Suction cover 1700#
    Inter-stage 2000#
    Also a couple of smaller items between 50# and 200#
    Jul 2009
    Columbia, MD
    that is cool! it looks like you know what your doing
    Thanks! My motto is "fake it until you make it"!!!
    Chicago,IL
    Oct 2005
    Phoenix, Arizona
    Wow. thanks for sharing the pics. I would love to do a tear down like that. nice job!
    RTFM!!!
    Aug 2009
    Prattville,Alabama
    I've never seen that bearing bracket removed while the motor is still mounted to the discharge volute. Do you plan to replace the motor-to-volute o-ring? How about the discharge volute-to-condensor o-ring? Appreciate the pics. Very nice equipment room... once you get past the chilled water lines above the starter.
