    in a house, Appomattox, Va.
    generator install
    put this one in awhile back. customer had sod put in after work done. I like how running pipng underground gives a cleaner look.
Size:  74.2 KBName:  DSCN3654.jpg
    Col 3:23
    Feb 2013
    Phoenix, AZ
    Nice. KW? Auto or manual transfer?
    Aug 2001
    Pavilion, NY
    Looks excellent. What did you use to sleeve the gas line? The only critique is that the regulator vent needs to be 4' from the unit.
    Aug 2011
    Rockland New york
    wat size underground? poly pipe?
    it was either 17 or 20 kw. has auto transfer switches to two panel boxes inside. ran pvc conduit to genset thru hole in bottom of unit.
    we didn't do gas line, gas co hooked it up. I did rotate the unit so "back" was facing out-manuf wants 5' from exhaust to building openings, etc, and not enough clearance if facing away from house. has 5' from exh to house and still has 30+" for access to gen and elec cabinents this way.
    Col 3:23
