Results 1 to 7 of 7
    Sep 2006
    Alaska
    Current Sensing Switch
    Currently we have flow switches with a single pole double throw (Common, Normally Open, and Normally Closed). The ddc panel is wired to common and n/c. The fan on light is wired between common and n/o. I would like to replace these flow switches with a current switch that has a sigle pole double throw. I know I can use a relay with a single pole single throw current switch to accomplish the same goal. Just wondering if any company makes a sigle pole double throw current switch?
    May 2002
    Baton Rouge, Louisiana
    Functional Devices has them
    very soon it is you that will be pwned
    May 2009
    in the present
    What are you using the N/C contact for?
    Sep 2006
    Alaska
    Normally closed contacts go to the DDC panel
    Sep 2006
    Alaska
    Looked
    Quote Originally Posted by joey791 View Post
    Hey Joey791 I looked on their web page and could only find current sensors not switches.
    Jun 2006
    New Jersey
    May 2002
    Quote Originally Posted by simux View Post
    Simux, I'm sorry I misread the datasheets
