Results 1 to 9 of 9
    im working on a coleman furnace,i have 24va at transformers going into the board,and i have 24va at the thermostat terminal until i turn on the heat,votage at my thermostat terminals on the board drops down to 16va,the furnace will light up once,then the voltage drops again,i have already change the board.
    Sorry, this isn't a DIY site.
    Oct 2006
    dont like coleman furances
    this is in mobile home right
    Florida
    If you're a pro, register as such and post in the pro area. If you're not, you only have a few more parts to change out, as the board wasn't it.
    Jan 2003
    Kentucky
    lmao
    Oct 2006
    I don't think this guy beenthere is a pro I bet you don't have the answer to this one thats why you give him the DIY crap anyway check the voltage at the gas valve
    ROFLMAO.
    You lost that bet.
    See what happens when you DON"T THINK.
    I could tell you whats wrong with your gas valve, but then your brain still wouldn't be thinking, and it needs some exercise.
    Jan 2003
    i'm not sure what this residential hvac site is about. "no diy", "pro have to register", can we all just get along?
    fjcool, there is a diference between 24va and 24vac. a 24va transformer is a bit small if you have humidifier (or other things) tied into it also.
