Results 1 to 13 of 21
    Jun 2011
    Severna Park, MD
    pilotless hot water tanks
    Hi Guys,
    Can a natural gas pilotless hot water tank be manually started? I understand how my heating system (furnace) operates and know it needs power to operate. But, in times of outages, I would like to have hot water.
    Thanks for any replies.
    Ken
    No. Might want to look into a small generator.
    Jun 2011
    Severna Park, MD
    Hi,
    Thanks. Yes, I've been looking at transfer switches as I have a generator, but, thus far the outages have not been prolonged to the point of real concern. I was just thinking there can be a way of triggering the gas control device manually.
    Ken
    It takes electric for the flame sensor to prove their is a flame. Without proof of flame, the valve closes.
    Jun 2011
    Severna Park, MD
    I'm having a difficult time trying to figure this out. This is a gas system with "no" electrical connections? Is there an internal spark generator of some type?
    If its pilotless. There has to be electric running to it. It has to have either a spark or HSI ignition system. And a flame proving system. HSI will use the HSI to ignite teh gas, and then to prove flame, spark will use a flame rod.
    Post brand and model number.
    Jun 2011
    Severna Park, MD
    Hi,
    Thanks for your patience...
    It's a "State" brand Model GS650YRBT. There is one wire leading from the top of the control valve to spark igniter(?) inside the unit.
    The GS6 models I see. All have pilots. And piezo ignitors for lighting it.
    Virginia
    are you sure its pilotless have you tried it with out electric . the sprk ignitor is used to light the pilot
    Stuff happens
    Jun 2011
    Severna Park, MD
    Yeah I get that part. But, I'm thinking when the temp drops, the water temp sensor (thermocouple/thermistor ckt) creates a miliovolt to fire the "Piezo", thus the gas valve opens(?)
    Virginia
    the piezo is just to light the pilot if it goes out ,look real cloes and see if there is not a pilot light
    Stuff happens
    Quote Originally Posted by Abuello View Post
    The piezo is manual. If the pilot goes out, you have to light it using the piezo.
    The temp sensor is mechanical. It doesn't generate any electric. So if your power goes out, you will have hot water as long as you have water coming to the house.
    easy way to tell if it uses electricity, does it plug into the wall anyplace?
    no cord to an outlet, then it is not powered by electricity!
