    Jan 2003
    Kansas City
    RTUA 100 fan control bias
    I was checking the service settings on this R-22 machine and found a setting for fan control bias (-50 to +50) Default setting in the IOM is 0 and this machine is set to +2. The IOM doesn't explain what this setting represents, so is it a pressure offset, a response time adjustment or something else?
    hi James!
    ya think brady quinn will save the Chefs???
    LMAO!!
    it most likely has to do with impedance.
    either 4-20 ma or 0-10 vdc from a remote thermistor if there is a potentiometer or a controller that operates the fans and the signal does not match or correspond to the setpoint.
    this could be achieved with a resistor or on the human interface panel?
    something like that?
    just a wild guess!!!!!!!!!!!!!!
    frank
    true knowledge exists in knowing that you know nothing.
    Jan 2003
    Kansas City
    The only thing that will save the Chiefs is a boycott. Stop paying for the tickets and the owner may be motivated to put together a functional coaching staff and team.
    well atleast sunday should be good!
    #31 vs #32!!!!!!!!!
    should be pretty even!!!!!!! LOL!!!!!!!
    up in the hizzy
    Quote Originally Posted by james mo View Post
    The bias pot is use to override the set point of the variable speed fan control, crank it up and fan will run faster, do the opposite to make go slow.
