Results 14 to 25 of 25
    Jul 2010
    South Florida
    Take a large plastic garbage bag and wrap it around the condenser. I usually let the fan hold it in place and charge the system its quick and easy.
    May 2002
    Quote Originally Posted by hands View Post
    They would probably do the same if you were caught with a control panel open and you didn't have your PPE gear on, but that never happens either does it.
    you are correct
    mikeacman
    Apr 2011
    Coastal Maine
    Quote Originally Posted by rcac101 View Post
    Hard to find a big enough garbage bag for a Rooftop Unit. That trick works until it gets really cold.
    Feb 2007
    Georgia
    .....back in the day with r12 we had heaters(electric) that went on a 30# drum and Robinair (are they still in business) had a charging cylinder that had a heater in it.
    But all that is a little over the top!
    Oct 2012
    CA
    Carefully cycle outdoor fan motor by hand ?
    Oct 2011
    Chicagoland Area
    5 gal bucket with hot water. 30 lb jug fits right in there.
    Feb 2007
    Georgia
    He has to weigh the charge in.
    But I will use that cardboard to block the condenser
    Jun 2006
    midwest
    Use your recovery machine and weigh in . Works every time
    May 2002
    Quote Originally Posted by gwoner View Post
    3 votes for this so far ,,,,it's what I do ,,,,and by the time you dick around with cardboard and bags,fire ,hit water (we had a guy blow a jug up doing this ),having to drag them on/ off the roof ,dispose of it or save it ,,,its just as easy and probably faster to pump it in with your machine ...
    Sep 2006
    Ohio
    Using a recovery machine is a good option, but you should have it connected to your charging hoses and pull a good vacuum on it to remove any moisture first.
    Sep 2012
    Ottawa, Canada
    Wait till the spring or you will end up doing it twice.
    Apr 2011
    Coastal Maine
    Quote Originally Posted by tim79 View Post
    Can't always wait till spring. What if the RTU cools a critical area? It is just something we have to deal with north of the Mason Dixon Line.
