Results 1 to 13 of 13
Thread: Lenox Air to acetylene setup
10-26-2012, 02:07 PM #1
I have been combing thru the forum to try to find out about air to acetylene setup like turbo torch. I got my small kit currently but I am trying to find out what type of solder I can use. I see about Stay Brite 8 but can I use 5% Brazing rods? I don't think I can because of the higher temp needed. But I haven't tried and I want to get something for practicing brazing currently. What you guys suggest? Currently in school we got oxy-acetylene setup with brazing rods.
I saw this forum thread but didn't get any info on Turbo torch setup : http://hvac-talk.com/vbb/showthread....rd-stick/page7
let me know what you folks suggest
10-26-2012, 02:08 PM #2
Air/Acet will work with braze 5%
10-26-2012, 06:40 PM #3
- Oct 2012
- 12
10-26-2012, 10:24 PM #4
Professional Member*
- May 2008
- Missouri
- 2,645
Years ago we tried the "turbo" torch sets, and others like what you've shown. Finally just gave in and bought the oxy/acetylene torch sets. Now we've got a bunch of them and have no regrets at all. Work fine and keep spare tanks available for crews. If you take care of them you'll only buy the set once. But then again the company furnishes torch sets (and tanks as needed).
10-26-2012, 10:35 PM #5
Ya... Haha..I am kinda getting the same feeling. I got a pack of 5% brazing rod. Umm... takes a little while for solder to flow. But once it starts flowing I can move it around. But then again ... I am pretty sure there is easier way braze with a setup like this and I just have to figure it out. Loll. Practice makes perfect. LOL. I think currently the problem I am having is the feather like flame tip is too long. I think I need some other tips to braze. I read somewhere that a MSA-8 turbo torch quickconnect tip is really good and it gives a rosebud flame.
10-26-2012, 11:04 PM #6
- Aug 2012
- Gainesville, FL
- 237
I've done a lot of 5% with a Turbo torch. Mostly potable water and medical gasses up to 3", but it works fine, just takes a little longer. For the bigger stuff you need the bigger tips, and boy does that thing scream.
10-28-2012, 07:18 AM #7
I use a turbo torch for 15% braze rod. Just need the right size tip.
10-28-2012, 11:54 AM #8
I use my turbo torch all the time for brazing or soldering. Granted, the largest units we braze are 5 ton, but they work great. They are also good for soldering when you have a pipe that won't quit dripping. Both have their place, it will really depend on if you plan to go residential or commercial.
Pros: Relatively inexpensive, replacement parts at all supply houses, only one tank and regulator to keep up with.
Cons: They are not as hot as an oxy setup, & they scream like a howler monkey.
"I don't know why it be like it is, but it do"
10-29-2012, 09:51 AM #9
10-29-2012, 10:10 AM #10
- Jul 2012
- Kansas
- 77
Try practicing outside in the wind, with a wet rag on one side of the joint. Then imagine R&R a reversing valve. I'm not saying it can't be done, but your rag may be dried out and on fire before you finish.
10-29-2012, 10:36 AM #11
10-29-2012, 03:52 PM #12
- Sep 2012
- NW Louisiana
- 156
Oxy/Acetylene is the only way to go, IMHO. Turbo torches scream and take longer to heat the joint. Kinda like using a MAPP torch. I use 5% and 15%, Oxy/Acetylene gets it hot, gets if flowing, and gets you out before you start to boil your rag. Maybe since I don't torch as much as some of you, Oxy/Acetylene helps me make good joints.
I look at is like this. Air/Acetylene is like a MIG welder. Nice in the shop, sucks in the wind. Oxy/Acetylene is like GMAW (Stick) welding, universal and tolerant to weather extremes. With Oxy/Acetylene just carry cutting head, welding tips, and rosebud then with one set of bottles can solder, braze, weld, and heat!
CT
10-31-2012, 02:02 PM #13
- Sep 2007
- SW Ohio
- 233
I've used a Turbo Torch mainly for 40 years and have been fine with 15% and most of the others. At times I've had to use Oxy/Acetylene but 98% of the time I just use the Turbo, wind or not. If you already have it, try it to see if it meets your needs.
