    Nov 2010
    cali
    air handler drain line.
    I have an dehumidifier in the room that has a condensate pump to pump out the water can I add an aditional vent after ptrap on primary line to run dehumidifier hose to or will this cause a backup in unit/ pan. This is probably a stupid question but nevver been in this situation. So basically I would have two vents on primary drain line after p trap.
    May 2012
    San Diego, CA
    My question is why you would want that? Primary drain getting overfilled?
    You can call me Sam
    It should be a crime to be a mechanical engineer in San Diego
    Summer Design Temperature: 83 F Dry Bulb ~ 69 F Wet Bulb (California Climate Zone 7)
    May 2011
    tallahassee,fl
    Yes u can do this after trap, done before, the further u get downstream of a/h the better.
    Jan 2005
    where it's nice and warm
    This should only be done if the ac overflow safety switch turns of both the ac unit and the dehumidifier.
    Nov 2010
    cali
    Why would it overflow unless something clogs the line that drain is capable of 10 tons.
