Results 1 to 11 of 11
    May 2011
    NEPA
    R-22 replacements
    I was wondering what how well the R-22 replacement refrigerants work. I have a walk in cooler at my cabin which developed a leak at a flare over the summer and rather than shelling out the dough for a cyl. of the real stuff I thought I'd try the replacement. (at about half the cost) Also wondering how the operating pressures compare. Thanks.
    Gainesville, FL
    Lots of threads on here about Isceon, MO99, Nu22, 422b, 407c, 414b, 438a, etc. ad infinitum
    May 2011
    NEPA
    Quote Originally Posted by Pete838 View Post
    Which of these are direct drop in replacements?
    Gainesville, FL
    MO99/438a is the closest as far as properties/pressures, but there is no "drop-in" you can top off 22 with a secondary gas. It will only save you 20 or 25 percent, though. DuPont has a video on YouTube with more info.
    Dec 2000
    Flat Rock, NC
    I give a vote for 407c. Two installs w/ 3 units and one conversion w/ no callbacks yet.
    Jan 2011
    Ward, Arkansas, United States
    http://coolantexpress.com/
    Just heard about this website today. Sounds like a bunch of b.s.
    "Gentlemen. You can't fight in here. This is the War Room!"-Dr. Strangelove (1964)
    R-22 replacement= r-410a
    Feb 2007
    Georgia
    Not for refrigeration med temp
    Phoenix,AZ
    Quote Originally Posted by Hunter844 View Post
    Yeah, they only give you 12lbs!!!
    Because Coolant Express 22a Refrigerant is so efficient you will use up to 40% less! Please see equivalencies below.
    The 30 lb cylinder = 12 lbs of Coolant Express Refrigerant and is EQUIVALENT to 30 lbs of R22a
    The 50 lb cylinder = 20 lbs of Coolant Express Refrigerant and is EQUIVALENT to 50 lbs of R22a
    Each ounce of Coolant Express 22a Refrigerant is equivalent to 2.5 ounces of R22.
    Southeastern Pa
    Quote Originally Posted by KB Cool View Post
    MANY years ago, in the 1990's, I was doing 134a conversions on R12 systems in cars. The guideline was that you could only charge 80% of the weight of the R12 system label value once you had replaced the receiver or accumulator (depending on the system) and drained out whatever oil you could.
    That's probably the reason they say you need less.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Feb 2007
    Georgia
    One of the main things that affects that(how many pounds you need) is the refrigerant density.
    Goto a thermophysical properties chart for r717 and r22 and compare lb per cubic foot. R22 is over twice as dense.
    R22a should publish same info as well as what the components are.
