Results 1 to 7 of 7
Thread: Scotsman cme256
    Jul 2009
    Scotsman cme256
    Just wanted to throw this out there. Where I work, we have a Sctotsman cme256, and the ice seems to pile up against the bin door, so that when it is full, which it usually is, and some one goes to get ice, a lot winds up on the floor. I have cheched everything I know how to, even shimming it up so that it tips back a bit. But no Luck. The ice seems a bit wet too, but only on the top of the heap, so it's the newest ice. Also, the room that the machine is located in, is small and pretty warm. Can't think of much else. Any ideas.
    Thanks.
    Oct 2011
    Chicagoland Area
    You need a bin diffuser
    Jul 2009
    Ok, 2sac, thanks. Can you give me a quick description, because I am unfamiliar. I considered making a small "fence" or"dam" to hold back the ice, but I guess my better judgement prevailed, for now. Do you have a link, or lead on where I could get one? I googled it and not much comes up. Do these units usually come with one?
    Oct 2011
    Chicagoland Area
    You'll have to contact the manufacturer of the bin, not the ice machine. A diffuser is just what you described. It is made of plastic or stainless and mounts inside the bin behind the door
    Jun 2012
    What's the manufacturer's model and serial number for the bin?
    Chicago, IL
    Scotsman has an optional bin thermostat accessory that you could use to lower the ice level if desired.
    Jul 2009
    Thanks guys, I spoke to Scotsman today,and they confirmed the part number. The bin model number is htb250, so they say I need part #A32580-001. I'm going to have to order it from Long Island I guess.
