Results 1 to 9 of 9
    Oct 2012
    North Carolina HVAC Zone Requirements
    I have a split system in my 2 story 1200 ft townhouse in wake county NC. Gas furnace was replaced in late 2010, AC system was left alone (12 year old goodman). I just got a quote for a new AC system and was told due to code changes, any new HVAC equipment in 2 story houses in NC have to have zoning equipment installed at the same time or it won't pass inspection. Quoted me $$$$ for the zoning equipment. Is this a scam?
    Mar 2012
    West Chester, PA
    I've never heard of anything like this but I don't live in NC. It sounds absurd which probably only increases it's likely hood of being true. Hopefully someone from NC can let us know...
    Dec 2010
    I would be surprised if that were the case. Alot of home would be very hard, if not impossible to zone.
    And many HVAC contractor do not do it (to be nice).
    Rochester NY
    I thought I heard that before, but that it was for new builds not retrofit.
    Dec 2010
    On a Peninsula in NE NC
    Its true. Not 100% sure on replacement though
    And its for your benefit, and much cheaper than 2 systems
    Zoned is the proper way to do it, and the only way I would do it
    DC Metro Area (MD)
    I had heard that was the case for multi-level residential new construction (either one system per each floor or a single system zoned), but I highly doubt it is required for change outs of existing equipment. Hopefully someone can set the record straight here.
    Dec 2010
    Just made a phone call.
    Code if major remodel and new construction
    Replacement no, not required
    But again, zoning is the right way to do it.
    I would try to find the actual verbage in my nc code book but my laptop is having a tune up.
    Dec 2010
    Quote Originally Posted by Southern Mech View Post
    I would agree to the thinking on new construction. So many (most) 2 story homes in our area with one system cannot cool the 2nd floor without turning the stat to 65 degrees.
    It would be harder to zone existing ductwork if you cannot get to all of it for whatever reason. Plus, to design the ductwork for zoning is prefered IMHO.
