Results 1 to 13 of 14
    MSEA 5.2 and CCT 5.3
    Hello,
    We just patched our Johnson system to 5.2.10 and installed the new CCT 5.3.
    Now we can't launch the CCT from MSEA, under Tools. We can lauch it from it's own icon. The problem is that without being able to launch it from within MSEA, we can't use the ethernet passthru to communicate.
    Thanks for any help
    Apr 2012
    Cape Coral Fl
    Did you do all upgrades before installing 5.2.10? I think there were patches that needed to be done before upgrade.
    Apr 2012
    Cape Coral Fl
    Is the Java the correct version?
    Melbourne
    Quote Originally Posted by integrator View Post
    you didnt place the dead chicken inside the pentagram before you put the silver dagger in did you???
    ...now youre gonna need some 'eye of newt' prepared by a zombie
    tsk tsk
    ...I couldnt help myself...its one of my favourite jokes about Johnson MSEA...sorry in advance for poking fun
    1 + 1 = 3 ( *** for very large values of 1)
    Be brave. You cannot get eaten by an imaginary tiger.
    Nov 2005
    Shreveport, Louisiana
    Quote Originally Posted by Tech83 View Post
    The patch is exclusive and can be installed with out previous patches installed. As for CCT passthru you shoudl try to uninstall CCT and reinstall it...
    UA Local 141
    Nov 2005
    CCT 5.3 has a bacnet router connection option now, you do not have to open CCT from the tools menu to use the CCT ethernet.
    UA Local 141
    Nov 2005
    OMG I let the secret out!!!!!!!!!!!!!!!!!
    UA Local 141
    Beachwood, NJ
    If you upgraded your CCT to 5.3, you will need the 5.2.5.0100 patch for passthru component to work properly on your pc or laptop. Email me and I can send you the patch.
    Nov 2005
    Quote Originally Posted by hvacpilot View Post
    They already have 5.2.10 patch.
    UA Local 141
    Nov 2005
    Uninstall CCT and reinstall it and you will be fine or use the bacnet router option in CCT ......
    UA Local 141
    Jun 2007
    On a similar subject, has anyone figured a work around to get PCT through an FX to work when it's at a remote site? Locally we are good, but anytime we go remote it's not accessible. (With pcg controllers bacnet routing enabled..... of course)
    Sorry for the hijack.
    Oct 2009
    Quote Originally Posted by kontrolthis View Post
    Yeah forward port 47808
    Nov 2005
    [QUOTE=kontrolthis;14613711]On a similar subject, has anyone figured a work around to get PCT through an FX to work when it's at a remote site? Locally we are good, but anytime we go remote it's not accessible. (With pcg controllers bacnet routing enabled..... of course)
    The IP port in the bacnet network needs to be enabled and be sure you know the network number of the trunk of the device you want to see....
    UA Local 141
