Results 1 to 13 of 27
    Sep 2012
    Orlando, FL
    Carrier Infinity vs. Performance
    What is the difference between the Infinity and the Performance series heat pumps/air handlers. Most notably the 16 ton systems. The specs that Carrier posts on their website makes it look like they are nearly identical, except for a slight increase in seer value with the Infinity heat pump.
    Really, what does Infinity bring to the table?
    Austin, TX
    Better comfort. More precise control of your heating and cooling system that minimizes operating cost and maximizes comfort. A thermostat that monitors a lot of conditions with your equipment and will alert you when something happens that will develop into unreasonably high utility bills or an expensive repair if not corrected. A system that logs malfunctions and makes it easy to track them down. When used with the Infinity zoning system, it can give precise temperature control to each zone and modulates air flow to each zone so they reach set point at the same time.
    We can each have a car that gets 40 mpg. One is a Fiat, the other is a Lexus. Which has the quieter ride, nicer seats and better stereo? Seer ratings, like mpg ratings, doesn't tell you everything.
    I am for doing good to the poor, but...I think the best way of doing good to the poor, is not making them easy in poverty, but leading or driving them out of it. I observed...that the more public provisions were made for the poor, the less they provided for themselves, and of course became poorer. And, on the contrary, the less was done for them, the more they did for themselves, and became richer.
    ― Benjamin Franklin
    Sep 2012
    Orlando, FL
    Quote Originally Posted by scooterfj62 View Post
    Obviously meant to say 16 seer systems.
    Jul 2010
    wisconsin
    Additional infractions may result in loss of posting privileges.
    Sep 2012
    Orlando, FL
    Is there any benefit in pairing a Performance air handler (FV4) with an Infinity heat pump (25HNB6). Or would I be better served going with matching series, either all Performance vs. all Infinity, budget dependent.
    Jul 2010
    wisconsin
    tiger man
    Rochester NY
    Getting the infinity AHU and control is critical.
    The pump is less critical. I have had noise complaints on performance series. Where will od unit be located?
    If Fiat is ok with you, you'll probably be very happy with 2 stage unit. If Lexus is required infinity or GREENSPEED may be abetted choice.
    Sep 2012
    Orlando, FL
    Quote Originally Posted by tedkidd View Post
    Interesting as our contracted quoted the opposite, Infinity heatpump with Performance AHU.
    OD units will be located in backyard just off the patio.
    Saint Joseph, MI
    You're paying a LOT for a communicating board and a fancy badge on an Infinity 17 Heatpump when you'd don't have a communicating indoor unit. The Performance series 2 stage heat pump is virtually identical. The Comfort Series is the same compressor, but not quite as good of a sound proofing package and a cheaper enclosure.
    Rochester NY
    They might want to find a contractor who understands what communicating means and does, at least a little bit, eh moto?
    Scooter, one of the reasons you REALLY want communicating is the equipment will tell you things like External Static Pressure. This is useful for knowing if they oversized your equipment to your duct, knowing when the filter get's restrictive, etc...
    If they discourage you from having this equipment you gotta wonder, what is it they don't want you to know?
    Saint Joseph, MI
    I agree. Just the fact that a contractor would match an Infinity Condenser without and Infinity Indoor unit is pretty telling. It shows a lot of ignorance IMO. It tells me they need a lot more education and training on the equipment. Its' not like Infinity communicating system are new. I think it's well past 10 years old. Time to find another Carrier Dealer.
    Rochester NY
    Yeah, I think Infinity started around 2000. But the big change - the communicating features started 2004.
