Page 3 of 4 FirstFirst 1234 LastLast
Results 27 to 39 of 47
  1. #27
    Madison, WI/Cape Coral, FL
    Quote Originally Posted by dan sw fl View Post
    FL Mother Nature provides an abundance of the nice humidity control
    in the next 6+ months with
    cool mornings like today. 45'F Dew Point
    http://www.wunderground.com/cgi-bin/...weekday=Friday
    Florida Humidity Control. Good enough for some, but typical FL Weather.
    I like the steady less <50%RH that a dehumidifier provides.
    Regards TB
    Real FL Weather
    11 9 12 FOS-789834-39-095535.pdf
  2. #28
    Aug 2012
    Florida Space Coast
    Quote Originally Posted by teddy bear View Post
    Hope you included fresh air and humidity control when there is low/no cooling loads.
    This is a complex expensive system but this type of system needs significant cooling load to remove the moisture from the occupants and adequate fresh air ventilation. A small ventilating dehumidifier would make the system complete.
    Keep us posted.
    Regards TB
    Humidity is quite pleasant this time of year when there's no cooling load. Plenty of fresh air, too, as I open the atrium sliders to enjoy the outdoors. No need for mechanical add-ons!
  3. #29
    Aug 2012
    Florida Space Coast
    Greenspeed Install Pix
Size:  13.7 KBName:  2012-11-09_09-13-04_893.jpg
Size:  37.0 KBName:  2012-11-09_09-13-25_565.jpg
Size:  35.6 KBName:  2012-11-09_09-13-59_40.jpg
Size:  32.1 KBName:  2012-11-09_09-14-32_36.jpg
Size:  33.2 KBName:  2012-11-09_09-16-01_14.jpg
Size:  33.3 KBName:  2012-11-09_09-18-52_156.jpg
Size:  18.9 KBName:  2012-11-09_09-19-17_450.jpg
Size:  20.2 KBName:  2012-11-09_09-21-42_588.jpg
  4. #30
    More info than you want. I am attaching a pdf of the outdoor dew point affecting the indoor dew point. When the dew point inside below the outside dew point, a/c or the whole house dehumidifier are removing moisture. When the out dew point is below the inside dew point, the fresh air moving through the home is contolling the indoor dew point. The graph is this week which is typical of winter weather in FL.
    This gets -+ 80 cfm of fresh air in moderate winds.
    FL homes need a dehumidifier if they want dependable <50%RH during mixed weather.
    Regards TB
  5. #31
    Delaware
    Always here
  6. #32
    SW FL
    Quote Originally Posted by Florida Joy View Post
    http://www.amazon.com/AcuRite-00325-...ef=pd_sim_hg_4
    Designer Dan
  7. #33
    Aug 2012
    Florida Space Coast
    The touchscreen controller for the Greenspeed displays humidity, but I picked up the below item at Home Depot for about half what they sell for on Amazon. It also tracks high/low temp/humidity over time.
    http://www.amazon.com/La-Crosse-Tech...sse+technology
  8. #34
    Rochester NY
    Wow. That is really nice. It will be very exciting to see if your bills go down and comfort goes up to or beyond expected levels.
    I'm keeping my fingers crossed.
    While this process is fresh in your mind, any comments or observations about the decision making process, suggestions/advice to homeowners from the ho perspective?
  9. #35
    Oct 2010
    Looks like they did a great job. I'm glad you finally found a good contractor and got a good unit. I'm glad we all could help you through your decision and best of luck in the future.
  10. #36
    Jun 2001
    Clean Install !!
  11. #37
    Jan 2013
    Space Coast, FL
    Nearby
    This is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise, commentary, or ask questions of the OP here. Please apply to the AOPC today, thank you.
    Further infractions may result in loss of posting privileges.
  12. #38
    Aug 2012
    Florida Space Coast
    Quote Originally Posted by MM-Wave View Post
    Hi FL Joy,
    I have enjoyed reading about your installation.
    I'm located nearby (and am also participating in the FSEC study).
    I expect that I will be replacing my central a/c system this year.
    It appears that you were satisfied with your contractor.
    In part because I am interested in installing a similar equipment, I would like to know which contractor you used to install your Carrier system.
    Thanks,
    MM-Wave
    Your post will disappear soon because you're not allowed to post in someone else's thread. Click on my username and you'll find my email address in my profile. Then you can send me private email.
  13. #39
    Jan 2013
    Space Coast, FL
