Results 1 to 13 of 14
    Dec 2011
    Twin Cities Minnesota
    RUN AWAY FURNACE !
    Guys.,headed out tomorrow on a 3yr old Goodman furnace that customer said was running when she got home after work,temp 105 degrees in house. She says she caught it once earlier this year acting "funny". May be an intermittent problem. Any thoughts if not obvious?
    Houston,Tx.
    Quote Originally Posted by Cosmicmuffin View Post
    First thing I would do it install a digital stat, then set the temp. limit at the stat for heat, you can do this with a simple Honeywell FocusPro 5000. If this don't help, you might have the red stat wire trickling to the white somewhere from the furnace to the stat.
    May 2009
    Cumming, GA
    Mr. Bill is on the right track. Sounds like a thermostat program/malfunction issue or a low volt short.
    Jul 2009
    Columbia, MD
    i would say R is touching W
    Calgary, Alberta
    Could be a white Rogers t-stat.
    They like to do that...
    Dec 2011
    missouri
    I have seen this happen with w/r thermostats when the batteries go dead. I also had a humidistat bringing on the heat due to being miswired. Maybe something to check, good luck!
    michigan
    change the batteries. happened at my house a couple years back
    Dec 2011
    somewhere between here and there
    mr bill...... after 14thousand posts......the red wire????? and the white wire?????
    OMFG......
    im in trouble cause i only got a white and a black wire.....I dunno whAT to do?
    Please, Please Please......keep the Factory Smoke in the Wires!!!!!
    Is it Rum'Oclock yet???
    Dec 2011
    The Red and White are the obvious..,the Factory Rep. says to check the gas valve.,will let all know soon!
    Houston,Tx.
    Quote Originally Posted by BigBacardi View Post
    OMFG......
    WELL, WHEN YOUR SOMEWHERE BETWEEN HERE AND THERE, i CAN SEE WHY YOU MIGHT USE THE BACK WIRE FOR HEAT, WAS THERE A MESSAGE HERE? Go have another Rum and Coke you will figure it out. What does post count have to do with anything? Obammy has been the President for 4 years and still don't know which end is up.
    Dec 2011
    Replaced thermostat..,no further call backs!
    Nov 2007
    Mississippi
    Was it a w/r touchscreen? Mine did the same thing. Replaced my stat and also added mechanical stat in return (to open "w"). No more problems.
    Grand Rapids, MI
    Probly a LUX or Hunter t-stat, go for the gold with a honeywell brand or WR.
    luck dan
