Results 14 to 26 of 41
    Fort Worth, TX
    Minisplit heat pumps are available.
    Building Physics Rule #2:
    Building Physics Rule #3:
    Jul 2012
    Western KY
    Quote Originally Posted by soylentgreen View Post
    No, but that's because you left out 80% of our electricity usage!
    My Math:
    The PV system will be about $19k after rebates & tax credit, and should generate 7800 KWH/year. Our average utility bill with electric car usage and (estimated) heat pump usage will be about $150/month. PV system + Heat Pump should knock that down to about $15/month (mainly natural gas for the clothes dryer and water heater). So the savings is something like $130/month or about $1500/year. This implies a 12 year payback on the system. I've run the numbers, and you can make this payback period go up or down substantially depending on the values you plug in for cost-of-money vs. expected increases in electricity and gas prices, and estimates of how much more electricity we will use - we have one electric car but only drive a few days a week on average. So overall I'm pretty confident the PV system, as a pure investment, ranges from "mildly bad" to "screaming great!" depending on the assumptions one uses.
    I'm intentionally not including the cost of the heat pump, but I'm not sure it's fair to include that entirely in the calculation, since (A) our furnace is 25 years old and probably needs replacing soon anyway, and (B) there will be a substantial quality-of-life increase.
    See what I mean now?
    Oct 2012
    Tommy, I've asked the moderators to look into your posts, as so far you've been 100% snark and 0% content. I'm happy to entertain a strong disagreement if you bring facts and data, or even if it's just plain old crusty old-fart opinions to the table.
    But you are just doing content-free sniping here. I'd expect better on a "professionals-only" forum.
    I would love for you to explain what you think, and why you think it. I'm here to learn.
    Oct 2012
    Quote Originally Posted by Shophound View Post
    I thought that all minisplits were heat pumps... am I misunderstanding something? Are there non-heatpump minisplits?
    SW FL
    Thumbs up
    Several alternatives exist in the mini-split area.
    For example,
    two of Several Mfgs,
    http://us.sanyo.com/HVAC-Multi-Split-Systems
    http://catalog.mitsubishipro.com/cat...s-heat-pumps-2
    Designer Dan
    Oct 2012
    For example,
    Ok, I think I understand my confusion : although technically all Air conditioners are "heat pumps" in the thermodynamic sense, in the industry the terms have special meanings, e.g.
    • "Heat Pump" : a heat pump that works in both cooling and heating modes
    • "Air Conditioner" : a heat pump that works only in cooling mode.
    (which brings up the question: is there a "heat pump" that only works in heating mode? If so, what would that be called? Off topic I know...)
    Now I think I understand Shophound's original comment - they meant that I could use a minisplit for heating, not just cooling.
    I agree, and it's a good comment, though in this house the office is upstairs, so I think in the winter a minisplit used for heating wouldn't do a good job of heating the whole house. I suppose that might be workable - just heat the office during the day and leave the downstairs unheated.
    Jul 2012
    Western KY
    Ok. My professional opinion is its a waste of money, the solar thing. Your #s may be good, didn't actually look, in a perfect world where stuff don't break. In my opinion your probably closer to 20 years on the ROR. Now you will disagree and though out a bunch of previously researched data you have there in front of you. My point was it seems you already have the data and made your decision. And I doubt anyone here is going to change your mind.
    Jun 2001
    Another thing to consider is going all electric and dropping the monthly gas meter fee. In our area it's $28/month just for the meter to sit there no matter if you are using gas or not. We need to save $336/yr by using gas vs. electric before the meter pays for itself. For us we have almost everything gas, because once you pay the meter fees, the gas itself is relatively cheap. If we had electric or heat pump heat the gas meter fees wouldn't be justified.
    Probably don't matter what we tell ya. You got it all figured out.
    Let's keep it professional. This wasn't called for.
    Oct 2012
    Ok, fair enough and thanks for clarifying that. How about we agree to disagree on the question of Solar panels?
    What I really came here for was advice on HVAC, specifically whether a heat pump makes sense in a mild climate like San Diego, and if there are any things to look out for, whether my calculations of converting Therms to BTUs to KWh etc. are in the ballpark, stuff like that.
    Oct 2012
    Ouch, sounds like you all in OK are getting the raw end of that deal! Here in California, in SDGE territory at lest as far as I can tell there's no "meter fee" at all. For gas I get billed per therm (11 therms for $10.44 last month). On the electric side, it's not so clear on the bill, but I see one source saying it's only a few dollars per month minimum billing.
    As for the future, anything's possible - they could change the rules, and the prices of Gas and Electricity could change. As you may have heard, our local Nuke plant (San Onofre) is having a bit of bother in the "series of tubes" and may or may not reopen. I understand that we are pretty close to an all-time low in natural gas pricing, too. Long-term, I can see the advantage of keeping the ability to use either gas or electricity as the market changes.
    Jul 2012
    Western KY
    Yes. A heat pump would work very well in the moderate climate.
    Mar 2010
    Morgan Hill Ca.
    Just curious if you have had anybody look into potentially going air to water?
    Radiant heat in the floors and heat pump generated domestic hot water..... You could still use water in a small air handler for heating and cooling also.
    I love cooking with natural gas, but some of the induction stoves that have come out lately are off the hook cool.
    Have you checked out these guys? Sun Run http://www.sunrunhome.com/?_nw=googl...FY6DQgodG1UAkA
    Curious to see how this thread progresses, I am somewhat in the middle of coming up with plans for an off the grid "forever house" and have looked into some systems that have me more than a little motivated.
    Good luck
