Results 1 to 13 of 13
Thread: glycol pump
10-20-2012, 03:07 AM #1
- Feb 2010
- 18
glycol pump
Hello!
I need to fill an HVAC system (air handlers and fancoil units) with the propylene glycol. The system total volume is about 9000 Litres (2377.55 Gallons).
The glycol package is a 55 Gallon Drum
What kind of PORTABLE pump will do the job? All I could find is Wilo-Bac
http://productfinder.wilo.com/en/DE/...ge_description
10-20-2012, 09:20 AM #2
Your not filling the system with straight glycol are you.
10-20-2012, 09:50 AM #3
Professional Member*
- Mar 2001
- 1,409
I alway used a multi stage booster pump to aadd glycol to an existing system. In fact I still have it. Haven't used it in 15 years, But,,,,I have it. LOL
One way to outthink people is to make them think you think. They'll think you're not really thinking what you're trying to get them to think you think...........
10-20-2012, 10:27 AM #4
- Feb 2010
- 18
It is a new system and I am filling the system with the 40% water-glycol mixture. Sorry for not being clear enough.
The points are:
-the pump must be able to suck from the drum
-the water-glycol mixture must be an approved fluid
There is no need in considerable delivery head because all the units are one the same level
10-20-2012, 02:09 PM #5
I use a utility pump with pvc pipe ran to the bottom of the drum.
10-20-2012, 02:24 PM #6
This is what I use:
http://www.johnstonesupply.com/store...ep?pID=W89-409
As stated by socotech, use a piece of 3/4 pvc to dip into the drum, make sure the end of pipe your putting in is cut at a 45* angle, if just flat cut end will sometimes suck to the bottom of the drum. I have a custom made cap from another drum that I uni-bitted a hole in so I screw that into the new drum and push my 3/4 inch down in and hold it solid, also another hole in cap to allow air to enter drum.
Need a 3/4" PVC MPT fitting so you can put a 6ft or so hose from the PVC to the inlet of pump. Out let of pump just use another hose and tie to the fill bib of the system. Make sure to prime the pump with water or whatever and your off to the races.
Obviously if your system is piped properly should have air separators. I will usually have a ball valve before the separator to allow easy future replacement. I remove separator and throttle the ball valve until I my glycol/water mix starts burping out the top. Run the system pumps and keep burping and adding until all the air is out of system.
If system is piped right then can be an easy straight forward process, if not...can take quite sometime to get air out of certain areas.
Make sure your using the right glycol as specified by the manufacturer of the boiler...those new aluminum heat exchangers require a special mixture.
10-20-2012, 02:26 PM #7
- Jun 2012
- Northeast
- 120
I use a Liberty 331 utility pump and washing machine and 3/4 hoses. I can fill a 400 gallon system section in about 3-4 hours with alot of running around for changing valves and checking air venting points.
10-20-2012, 02:45 PM #8
- Feb 2010
- 18
Thanks for advice! Very helpful.
10-21-2012, 06:50 PM #9
- Aug 2006
- 2,444
Make sure you pressure test it with air first, glycol leaks are a B**** to solder, or braze.
11-02-2012, 10:45 PM #10
I would get a positive displacement pump from Grainger, their brand is Dayton. A Taco Pony Pump is what I have on the truck and it will take down a 55 gal. drum in 5 to 10 minutes up to 15 ft. or so of head. Make a dip tube like others have said and have fun switching all of the drums.
...RonRoof Rat
11-03-2012, 08:25 AM #11
- Mar 2001
- 1,409
Hmmm. I was doing a ten story building, thats why I had to use a booster pump.
11-03-2012, 02:23 PM #12
- May 2010
- Canada
- 304
I know when we fill the glycol skids on the second nature systems they want us to use distilled water. Nobody dose but I'm curious if they are asking you too as well.
Do you have holding tanks for the system?
11-05-2012, 09:58 AM #13
- Feb 2010
- 18
I always use a distiiled water to avoid any impurities like a chlorine. But on that site I have ready-to-use mixture.
Yes I have holding tank.
