Results 1 to 12 of 12
Thread: Sealtite snake
    Dec 2008
    Buffalo NY
    Sealtite snake
    Found this on a roof in Niagara Falls. Typical. Name:  ImageUploadedByTapatalk1350689823.272253.jpg
Size:  75.7 KBName:  ImageUploadedByTapatalk1350689835.365525.jpg
Size:  78.9 KBName:  ImageUploadedByTapatalk1350689849.426685.jpg
Size:  102.2 KBName:  ImageUploadedByTapatalk1350689862.044086.jpg
    Sent from my iPhone 4s
    using Tapatalk
    Join http://scopeny.org/ Shooter’s Committee on Political Education
    The world is full of sheep,try not to join the flock.
    Support the Skilled Trades, Don't DIY
    May 2012
    Upper Michigan
    Could have went under the gas line at least lol
    Jun 2012
    Are they running those data cables with the high voltage power to the condensing unit?
    What is that condenser?
    Dec 2008
    Buffalo NY
    I believe it was an EMI. I was up there working on an RTU.
    Gainesville, FL
    Quote Originally Posted by danbb View Post
    If its like most minis the line voltage feeds the CU, and it feeds power and a control wire to the AH. Most don't have a "data" cable or low voltage control cables.
    It kind of looks like someone could have pulled 120v FROM the condenser, probably the satellite guy. They don't operate by the same rules as the rest if us and they rarely have inspections.
    Jun 2012
    Quote Originally Posted by Pete838 View Post
    Ah, that makes sense, I though they had pulled the coax cables from the satellite through the sealtite and through the condensing unit's disconnect to get it into the building
    Oct 2007
    Austin Texas
    Dish heater? To keep ice off?
    Nemo me impune lacessit.
    How much blood do I have to bathe in to get clean?
    Don't look down on anyone unless you're helping them up.
    Sep 2012
    NW Louisiana
    Per NEC, no more than 6' of flex to a motor. I'd call a condensing unit a motor... Conduit is cheaper too.
    CT
    Rochester NY
    Quote Originally Posted by nsula_country View Post
    CT
    Unless you don't have any on the truck...
    Cincinnati, Oh
    CT
    As I'm sure timebuilder will say:
    "HVAC is special consideration, and that code does not apply."
    "Just get it done son."
    Dad adjusted
    Jun 2001
    I've seen many RTU's with protected thermostat wire running across the roof. After 2-3 years the sun dry-rots the insulation and results in a service call next time it rains.
