Results 1 to 13 of 15
    May 2012
    Upper Michigan
    2 challengers/boiler buddy
    Had an emergency change out. It's not finished and yes the gas tight looks like **** but I don't know what to tell ya.Click image for larger version.
ID:	319031Click image for larger version.
ID:	319041Click image for larger version.
    Dec 2010
    Toronto
    Have you used many Alpha pumps? How do you like them?
    May 2012
    Upper Michigan
    Quote Originally Posted by SolarMike View Post
    Those were my first alphas, there really cool, they are supposed to ramp down to nothing so you don't need a pump control. If they work like the should I think for the price they would be worth it. I haven't had a chance to really look into it but as far as I could tell they didn't shut off all the way.
    Jul 2009
    Columbia, MD
    they are nice pumps but, wont move a lot of GPM at higher head.
    i have read a lot of curve charts for various pumps. A lot of good info to read when you think you have the proper GPM for a boiler
    Sep 2012
    thomaston, ct
    Nice work
    Jul 2009
    Columbia, MD
    BTW, The job looks good.
    Jun 2006
    New Jersey
    This is a temporary setup?
    The electric to you zone circulators is just draped all over. Steel to Copper connections.......is a no-no. Is that an expansion tank laying on the ground with tubing to the drain of the buffer tank? Air separator?
    May 2012
    Upper Michigan
    It's not done yet, had 2 days to get it running for the weekend, also Waiting on the right size exp tank, I buttoned up the wiring after, also have a tekmar to install.
    Nov 2001
    Moose Jaw, Saskatchewan, Canada Occupation:Interprovincial Plumber, Commercial Gasfitter Interests:
    Quote Originally Posted by ascj View Post
    What's wrong with copper to steel? Spirotop on top of the boiler buddy.
    I love my job, but paydays Thursday
    May 2012
    Upper Michigan
    Cu to steel is fine in hydronics, ya it comes with a spyro vent.
    Jun 2006
    New Jersey
    I was not familiar with the Boiler Buddy.......but apparently a air vent on the top of the buffer tank is all that is needed. They incorporate air elimination into the buffer tank. As far as, copper to steel in a closed loop........it isn't black or white. So it's better to be safe than sorry.
    May 2012
    Upper Michigan
    It's mainly about electrolysis, a domestic water line is grounded and oxy rich. A boiler is neither. I helped a boiler maker change out the tubes in a 300 gallon water boiler, if a hole in the plate was to large a copper sleeve was inserted and the tubes were rolled tight against that. That is standard procedure and a state inspected job, after that day I changed my opinions.
    Poestenkill, NY
    Nice looking work!
    I don't see the point to a boiler buddy with a mod/con boiler but that's me. Seems like a really expensive way to decouple primary/secondary loops. Why not just do closely spaced tee's and a spirovent in one of the loops? Cast iron non-condensing non-modulating boiler is a different story, short cycling is much more of a concern ...
